Originally Posted by tuRBy
thanks, do you know whats the max lift you can run safely without pocketed pistons?
and whats the minimum duration i need with 11's?
9.2 lift is the safe limit for piston clearance and 10.00 lift before uprating the stock valve springs and retainers
I think the minimum duration for 11mm lift is 280
