Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > New Nissan GTR R35 > General R35 Nissan GTR Chit Chat
Old 27th March 2008, 02:40 PM   #1 (permalink)
Benji Linney GTC's Avatar
Speed delimit options for JDM R35's
I know a few people have JDM cars on route (except davew as he's not as hardcore as he used to be), so some info for you..
HKS Technical Factory have released the first standalone 180km/h speed limit defeat for the R35 GT-R. Other tuners like Mine’s and Power House Amuse have had products to remove the speed limiter based around ECU modifications but this is the first standalone product to do it to my knowledge. The VAC connects to your ECU harness and offers and on/off switch for some reason.
Expected to be priced at 96,000 JPY / £480
Garage Saurus and Autoselect have already received their VAC and are playing around with it on their own GT-R. Expect an update once their done with testing.
The other good news is that a cleaver UK electronics company has developed a similar product, which came out last week and is now on my R35. It's also alot cheaper at only £179 + vat etc.. with mph convert options is another £179.
The delimiter will remove the 180 KMH / 112 MPH factory programmed road speed limit which is standard to all Japanese imported Nissan R35 GT-R models.
For vehicles which also require a speedometer conversion from KMH to MPH, there is an additional output wire which can be connected to the speedometer speed signal input wire.
Overview And Installation
The Engine Control Unit on the Japanese home market Nissan R35 is pre programmed with a road speed limit of approximately 112 MPH, although with most converted speedometers, this will appear to take effect when the speedometer is reading around 120MPH. At this speed, engine performance is restricted to inhibit further acceleration.
Speed information is supplied to the ECU via the vehicles CAN (Controller Area Network) system, which can be found at the ECU as a twisted pair of wires. The CAN system carries a vast amount of vehicle data between controllers, some of which is used to enforce the road speed limit.
The delimiter works by analysing the vehicle data stream and re-writing the appropriate information to the ECU so as to defeat the factory limit function. This simply allows the vehicle to achieve the maximum designed road speed without restriction, the delimiter does not enhance normal engine performance in any way.
The delimiter is installed directly to the wiring at the ECU, behind the dash area on the passenger side of the vehicle. The delimiter wiring loom has pre-bulleted CAN wire connections fitted and is supplied with bullet connectors for installation to the cut ends of the vehicle CAN Bus wiring. The only other connections required are to a 12v+ power supply and to a good ground point.
The delimiter features CAN activity detection and will automatically switch off when vehicle CAN activity has ceased.
Full installation instructions are supplied with the unit, average installation time is approximately 40 minutes for delimiting and another hour for speedometer conversion if this is required. It is advisable to use a set of high quality, ratchet type crimpers to install the bullet connectors to the vehicle CAN wires and soldered connections for the power and speedometer wiring.
Wiring Details
White / Blue - CAN HI & CAN LO (LOOM)
White / Green - CAN HI & CAN LO (ECU)
Red - 12V+ Supply
Black - 0V Ground
Green - MPH Speedometer signal
GTC
JAPANESE PERFORMANCE TUNING PARTS
Tel: +44 1438 833367 Mob: +44 7970646620
SUPPLIERS OF THE BEST JAPAN HAS TO OFFER
GTR 23
New Nissan R35 GT-R SUPER STORE - ENDORSED & PARTNERED WITH THE BEST TUNING HOUSES IN JAPAN & USA
PERFORMANCE EXHAUST UPGRADES * ECU REMAPS * DIAGNOSTICS * BRAKE TECHNOLOGY * SUSPENSION TECHNOLOGY * OEM GEAR BOX / ECU SOFTWARE UPDATES * AERO DYNAMIC PARTS * JDM ALLOY WHEELS & TIRES * IMPORT & TECHNICAL ADVISE + MORE…..
MY UK NISSAN GT-R APRIL 2009
Benji Linney GTC is offline   Reply With Quote
Old 27th March 2008, 03:34 PM   #2 (permalink)
TSUCHIYA-KUN's Avatar
Send a message via MSN to TSUCHIYA-KUN
good info for futures R35 owners.Thx for share it
TSUCHIYA-KUN is offline   Reply With Quote
Old 27th March 2008, 03:41 PM   #3 (permalink)
Excellent post Ben. Many thanks for sharing the info with the forum.
Old 27th March 2008, 04:57 PM   #4 (permalink)
doggiehowser's Avatar
Q: does the HKS need splicing to join the ECU harness?
doggiehowser is offline   Reply With Quote
Old 27th March 2008, 06:46 PM   #5 (permalink)
Send a message via AIM to Spooled1.8
That is definately ALOT easier on the wallet than HKS' solution, thanks for sharing
Spooled1.8 is offline   Reply With Quote
Old 27th March 2008, 07:09 PM   #6 (permalink)
Armed English's Avatar
Lightbulb
I'm impressed! Did the GTR beat the 911 Turbo, M3 and R8 around Rockingham in the Car Magazine feature with it's speed limiter in place
Armed English is offline   Reply With Quote
Old 27th March 2008, 08:54 PM   #7 (permalink)
Jspeed's Avatar
Can u kindly tell me where I can order the UK product? I need one now!
Jspeed is offline   Reply With Quote
Old 27th March 2008, 09:36 PM   #8 (permalink)
davew's Avatar
hey Ben, thats fighting talk up north!!!
The GTR Shop - Skyline GTR Breaker and Parts supplier.
For all your GTR needs.
From 1/2 clips to turbos,
seats to shells ,
harness's to engines.
call Mobile 07731304953
GTR店 We ship worldwide.
davew is offline   Reply With Quote
Old 28th March 2008, 01:43 AM   #9 (permalink)
tokyogtr's Avatar
this is great. i'll be ordering one of these.
one question though is does this product stop the over speed warning light from coming on? once it comes on it will stay on until the car is restarted.
Old 28th March 2008, 02:27 PM   #10 (permalink)
it sure did, the day after coming out the container. But the Rockingham circuit was such that top speed wasn't an issue. Would like to do some timed runs of Silverstone etc..
tokyo- i havn't noticed it or any error messages
doggie- tbc but i doubt it
Jspeed- u have pm
davew- what can i say i though you were jdm ! once you were my hero with one of the first OS GTR that was in same league as say the Super Lemon
GTC
GTR 23
Old 10th April 2008, 04:04 AM   #11 (permalink)
tokyogtr's Avatar
so how does one go about ordering either of these? would like one of the asap.
Old 14th May 2008, 02:31 PM   #12 (permalink)
msia's Avatar
Ben, just got my R35... HKS VAC far too expensive. Please PM me regarding where I can get the UK-based delimiter please! Many thanks
Porsche 997 Carrera S
EVOMS Supercharged
Gemballa Bodykit
Nissan GT-R R35 JDM
Black
Black Edition
msia is offline   Reply With Quote
Old 15th May 2008, 01:46 AM   #13 (permalink)
[quote=Benji Linney GTC;866943]I know a few people have JDM cars on route (except davew as he's not as hardcore as he used to be), so some info for you..
This is absoultely fantastic.....Thank you!!! Now all i need is an english owner's manual!!
Once again, THANK YOU!!
GT-RRR is offline   Reply With Quote
Old 15th May 2008, 02:16 AM   #14 (permalink)
First's Avatar
So for delimit purpose would all of you have chosen this over Mines ECU?
Mines add 0.1 bar boost. Isn't that a much better option?
TokyoGTR, I suppose you wanted this because the Mines ECU wasn't out then?
First is offline   Reply With Quote
Old 15th May 2008, 02:18 AM   #15 (permalink)
tokyogtr's Avatar
not really. i just didn't realize the mine's would offer other performance enhancements. if i'm going to void the warranty, might as well get some tweaks along the way. the .1 boost, better torque curve plus speed delimit were all a bonus. also, it's just come out that the hks system switches off the satnav while it's on. not sure what the other product does. being in japan i actually use the satnav.
