They will work but you have to bypass the factory injector resistors, I dont have a pic on me, maybe someone here does.
The factory gtr injectors are low impedance, but there is a resistor box in parallel with each injector to bring the impedance up. If you remove it and just hook up the injectors directly you should be fine.
Im not 100% sure on this, but i think you can just cut the resistor box off about 30mm long, strip all the wires and put a crimp lug on them and this will do the trick.
