Old 20th April 2008, 12:25 PM   #31 (permalink)
gibson's Avatar
as yours also make no sense to me .. you say that the only issue was running the oem damper ..so that impiles that you had bottom end problems ?
I have gone on my own experience and have sort infomation on the subject ..i believe that the issues where resovled in 1999 in Australia and have only changed a liitle from then track cars have been running the above set up and i would sufggest that you read the link to skylines australia sydneykids thread is one the best i have read on this forum... each to there own but saying that you ran yours with the problems that you found on rebuild ....could they have been different with more info. as for preaching no its tried and tested.. you have your approach yes but don't go around say that anothers is bull just because you may not have tryed it.
Your last comment about cavitation and running the sump dry like i said its all related to keeping the engine a live under changing conditions.
where is tynado he will explain this.
Look up google I'm done
gibson is offline   Reply With Quote
Old 20th April 2008, 12:36 PM   #32 (permalink)
TP_
Why shouldn't i run with my balanced oem damper?
TP_ is offline   Reply With Quote
Old 20th April 2008, 12:43 PM   #33 (permalink)
gibson's Avatar
Sonic vibration or some thing, ATI and others make dampers for differing horsepower to reduce these vibrations in the crank.I believe this also effects timing.
Old 20th April 2008, 01:36 PM   #34 (permalink)
blue32's Avatar
i think the ATI is ment to be a decent harmonic damper to get for the car from what ive read.
blue32 is offline   Reply With Quote
Old 21st April 2008, 12:04 PM   #35 (permalink)
TP_
Hmm okay. I will be running with my standard OEM damper, its balanced so it shouldn't be that bad. 9000rpm maximum maybe.
Old 21st April 2008, 12:47 PM   #36 (permalink)
Mr. Keets's Avatar
I wouldn't.
I've had this discussion with my tuner. He's a well respected guy with lots of hardcore builds under his belt and he tells me that there is a problem at 8500ish rpm and above. ATI or HKS
Mr. Keets is offline   Reply With Quote
Old 27th April 2008, 11:53 AM   #37 (permalink)
TP_
I believe my Tomei oilpump has come to my local postal office, going to get it in a few hours
Old 27th April 2008, 01:31 PM   #38 (permalink)
TP_
Tadaaaaaaaaaa:
Old 25th July 2008, 10:41 PM   #39 (permalink)
WRC
Hi, i have now broken the N1 pump on my time attack R32. I quess it didnt like the high revs. Its not completly broken , just the gears that have broken in some pieces. this broke the sealing, and made an big oil leak. still had oil pressure when this happened. but after reading this tread, i think i just will change the gears to Reimax gears, But who sells them, other than greenline??
cheers
WRC is offline   Reply With Quote
Old 26th July 2008, 07:31 AM   #40 (permalink)
GT-R Glenn's Avatar
Re oil restrictors.
You only need one in the front oil supply to the head, I used 1.5 mm
The rear one already has a plug in it from Nissan.
Old 27th July 2008, 06:45 PM   #41 (permalink)
WRC
cheers
anyone?? really need to order this kit from sombody soon
Old 30th July 2008, 10:00 PM   #42 (permalink)
TP_
Searched for 30 seconds on google and found this:
Reimax Oil Pump Gear Kit Skyline GT-R RB26DETT
Old 31st July 2008, 01:50 PM   #43 (permalink)
Send a message via AIM to noodl35
I'm sorry but for that price you might as well get a tomei pump...period.
noodl35 is offline   Reply With Quote
