Old 27th March 2008, 04:29 PM   #1 (permalink)
TP_
N1 oilpump VS Jun oilpump!
hello!
I stand between an N1 oilpump and Jun oilpump, what have you to say about my choice? The Jun pump costs for me at least 400 dollars more and would make my car stand 1 extra month before i can start it up.
Regards/ Mattias from Sweden
TP_ is offline   Reply With Quote
Old 27th March 2008, 04:34 PM   #2 (permalink)
Listerofsmeg's Avatar
Send a message via AIM to Listerofsmeg Send a message via MSN to Listerofsmeg
Jun over N1 every time.....the N1 isnt much (if any) better than stock.
White R33 GTR
Its working!!
10.908 @ 128mph on pump fuel and full trim!
Old 27th March 2008, 04:43 PM   #3 (permalink)
Spearmint's Avatar
N1's don't like many revs above 8000rpm.
Jun / Tomei everytime.
Spearmint is offline   Reply With Quote
Old 27th March 2008, 11:07 PM   #4 (permalink)
kismetcapitan's Avatar
I've broken both, so I'd say neither. However, when the JUN broke, it was just a hairline crack that leaked a bit of oil, and still delivered full oil pressure under some extreme driving.
When the N1 broke, it shattered into bits. I was parking the car when it happened. N1 is garbage.
Buy a Tomei or Reimax.
Old 28th March 2008, 12:03 AM   #5 (permalink)
What about the Nismo one? whats the difference between that and the N1?
rogerdavis is offline   Reply With Quote
Old 28th March 2008, 05:52 AM   #6 (permalink)
Nismo is stronger but flows the same as stock. The JUN flows a lot. A LOT. This is good, but also not so good. If you have ball-bearing turbos, the oil lines must have restrictors or the high oil pressure that the JUN pump generates will blow the bearing seals. The JUN can also suck a standard sump dry if the level is a little low.
Tomei has adjustable flow, which is why I bought one of those. I think overall, an extremely high-flowing pump has advantages over the disadvantages, but you really have to prep your engine for it. head oil restrictor. turbo oil restrictors. sump control/extended sump. And an oil catch tank - at high RPM there's so much oil being flung into the head that if you keep the crankcase vent connected to the intakes, you'll be burning oil, which is like dropping your octane 50 points when on boost. And who wants to run 50 octane fuel when you're boosting???? head oil drain - I haven't done it but some others have. Some say it's necessary, some think it's pointless. I don't know, other that it's something to consider.
A Tomei pump set to maximum flows about the same as a JUN, maybe slightly less. I ran 0W-20 oil for four months, and I think that the big flow of the JUN pump let me get away with that, maintaining pressure with water-thin oil.
Old 28th March 2008, 05:58 AM   #7 (permalink)
NBM33's Avatar
I Agree Richie...I had a New N1 oil pump fail , It totaled my Engine
NBM33 is offline   Reply With Quote
Old 31st March 2008, 07:06 AM   #8 (permalink)
so if I am not planning to go over 8k an N1 should be better than the tired original one, or just buy a new original oil pump.
greyBnr32 is offline   Reply With Quote
Old 31st March 2008, 07:21 AM   #9 (permalink)
you could, but that's a part of the engine I'd rather not be cheap on, least of all because you have to remove the engine to change it.
Tomei or Reimax. They have the strongest gears, which is really what you want to be concerned about.
Old 1st April 2008, 12:11 AM   #10 (permalink)
RomEG6's Avatar
well said
RomEG6 is offline   Reply With Quote
Old 1st April 2008, 04:44 AM   #11 (permalink)
TP_
I cant find Reimax anywhere on the net, but iv'e found some Greddy pumps. How are they then?
Old 1st April 2008, 05:36 AM   #12 (permalink)
Mr. Keets's Avatar
Reimax
I thought about the Tomei/Jun/N1 selection and I'm convinced that the way to go is the N1 with the Reimax gears. They flow the same as an N1 but have greater strength and as stated above the Jun/Tomei ones flow alot more leading to the possibility of sucking a sump standard sump dry at high rpm. There is a great thread on the SAU site regarding oil control. Oil Control In Rb's For Circuit Drag Or Drift - Skylines Australia
Mr. Keets is offline   Reply With Quote
Old 1st April 2008, 06:36 PM   #13 (permalink)
gibson's Avatar
oil pumps like everything on all engines comes down to the supporting items. Meaning the crank and vibrations from it ...how many of your failures had ATI dampers or similar. Cranks, rods pins and clutch balancing?? look at the big picture.. Mine is N1
gibson is offline   Reply With Quote
Old 1st April 2008, 07:41 PM   #14 (permalink)
rb30 710bhp
rockabilly's Avatar
Send a message via Yahoo to rockabilly
had 2 x n1,s on my rb26 620bhp 4000miles no probs 8000 limit all balanced, one on my rb26/30 all balanced 8000 limit done 1200 miles so far no issues, its vibration that kills them simple..get it balanced properly. bernie
fancy the south of france.
http://st-tropez.mysite.orange.co.uk/
Old 2nd April 2008, 04:14 AM   #15 (permalink)
TP_
My clutch, crank, damper are balanced. My Verdi rods and CP pistons are weight adjusted too.
After that i read the Australian thread about oilcontrol, it feels like the best way is to use the N1 pump and buy Reimax gears. Someone knows where to buy the except for Greenline.jp? People here in Sweden have had alot of problems with greenline.
