Originally Posted by Madden
Good stuff Pual. I was told max of 9.8mm before head mods. I didn't know you have to pocket the pistons **** that. I would just put a couple of headgaskets on
My 10.05 cams just clip the side of the follower bore so I think 9.8 would be good to fit with no head mods. Again with a 1.5 head gasket you should be ok for valve to piston clearance, if the block and head have not being skimmed. But to be certain and without removing the head its best to stick with 9.2 lift
I got those 280 9.15mm cams for £230 so just waiting on delivery. What effects would changing the cam timing have on the performance? i.e advance and retard the inlet or exhuast cam?
All you can do is book a dyno as there are so many variables, it would be best to check AFR and exhaust temps if possible.
