fyi the Power FC is 20x20. FCon is 32x32....stock is 8x8?? that sure makes mapping easy
I wonder what the map on the Z-Tune ECU looks like - if that's also 8x8.
higher resolution doesn't necessarily mean better. My car uses about 30% of the map - high-load/low RPM and high RPM/low-load never sees use.
And you can have the best ECU on the planet...and still torch your pistons with shitty mapping.
