xxl225
has no status.
tree hugger
Cars owned: a plough
can 't get the rear speakers working in my r32??? help
i have the correct iso the front speakers are on but no rears do i have to live up the rear amp or something??? do they even have an amp???
help needed as i'm in a pickle thanks al
lightspeed
is BNR32
Cars owned: Project BNR32
If you have the original Active speakers in the rear shelf then you need to run via the amp under the parcel shelf. Amp is about 12cm round Clarion or Panasonic?? unit.
Anything aftermarket and you can bypass the amp.
lightspeed
is BNR32
Not sure if mine was busted - but when I tried it didn't want to know.
Sounds fine without so the amp is in the garage gathering dust.
kismetcapitan
is like trees in November...
Toluene Junkie
bin the rears, they mess up the soundstage. You can fit 6.5" speakers in front.
There are only three true sports: mountain climbing, motor racing, and bullfighting. Everything else is merely a game. |
V1H
has no status.
what you can do is snip the wires from the amp(round thing? under back shelf, check first) to the speakers, do the same to wires to the amp then join those wires to the speakers (thus bypassing amp), then trace these wires at the centre console and attach to your head unit rear speaker output.
you're not missing much by bypassing the std rear amp and the iso adaptor isn't really a plug and play rather it just makes it easier to connect the wires up.
