Old 26th July 2008, 12:47 PM   #10 (permalink)
roadie
Your wideband should have a 0-5 volt output that can be wired into the datalogic. You then can log your afr's the same way it logs all the other sensor activity. IMO afr's (high 10/low 11) are preferred for high load/high rpm....
roadie is offline   Reply With Quote
