Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > Non-Skyline/GTR sub forums > Other Marques
Old 5th April 2008, 01:05 PM   #1 (permalink)
R33_GTS-t's Avatar
Location: [544] days from disposing of Labour. BNFL are shit. One repossession, one (bank) window.
Avro 720 Mirage (Ford GT)
Avro releasing limited-edition 720 Mirage Ford GT - Autoblog
The Brooklands-based tuning firm, Avro Motor Cars, has partnered up with Roush Technologies to offer up a run of ten limited-edition Ford GTs that not only get a fresh coat of orange metallic paint and a some matte-black details, but an extra helping of power. The 720 Mirage spells out its claim to fame in its name, with 720 horses coaxed from the modified V8. Utilizing a larger Whipple supercharger, an Accufab throttle body, inlet sleeve and X-pipe exhaust, the 720 unleashes its namesake at 6,950 rpm, with peak torque output of 627 lb.-ft. coming on at 4,800 rpm. The suspension has been modified with KW Variant 3 adjustable coilovers that drop the limited edition whip by 25mm, while AP six-piston calipers clamp onto drilled and slotted rotors courtesy of Stillen. There's no word on pricing, but we'd guess that if you tacked on a few more zeros to the GT's 220 mph top speed, you'd be pretty close to the sticker.
The Ford GT may be in the process of passing into supercar history, but that hasn't stopped Avro Motor Cars from taking one last spin at making the beast faster. The Brooklands-based tuner recently announced a 10-car run of modified GTs called 720 Mirage. Avro partnered with Roush Technologies to push the GT's power output to 720 horses. The company previously teamed up with Roush to produce the 600RE edition of the GT.
The additional urge comes courtesy of a larger Whipple supercharger and Accufab throttle body, inlet sleeve and X pipe exhaust, among other minor modifications. Specific output is 720bhp at 6950 rpm and 815Nm (627 pound-feet) torque at 4800 rpm. Unleash that power and the 720 Mirage will run to an un-governed top speed somewhere north of 220mph.
Suspension upgrades include a 5mm wider track and a 25mm drop, as well as KW Variant 3 adjustable coil-overs. Six-piston AP Racing brake calipers are used in the front, and drilled and slotted rotors sourced from Stillen are installed front and rear. The modifications are subtle but should help to ensure that the Avro 720 Mirage can handle its increased power with the same poise as the factory version.
The 720 Mirage stands out thanks to a distinctive metallic orange paint job with matte-black detailing. The wheels are blacked out as well. Avro adds special decals and sill plates, and ditches the GT's rear bumper in the name of weight savings for an even more exclusive appearance. Naturally, there's a numbered plaque on the console.
