Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > New Nissan GTR R35 > R35 Technical
Old 9th April 2008, 02:59 AM   #1 (permalink)
tokyogtr's Avatar
Geometry and tramlining
I'm getting a lot of tramlining with my GT-R at present. The performance center told me all gt-rs come with the geo setup for the circuit. If clients want the road setting then they can change it for a small fee.
Is anyone else getting extreme tramlining? And has anyone had their car geo changed to street mode?
Old 9th April 2008, 04:13 AM   #2 (permalink)
DCD
DCD's Avatar
Send a message via MSN to DCD
Normal for a GTR. Tramlining has a lot to do with the tread pattern of the tyre, the more longitudinal the design is the more it will follow road imperfections. I'd doubt you'd get much of an improvement with a straighter geometry set-up. I did notice it less on a R35 I drove with the Dunlops however
Old 9th April 2008, 04:59 AM   #3 (permalink)
tokyogtr's Avatar
in my exige i never had tramlining issues until i upgraded the suspension and made the geo more aggressive. then it tramlined like a SOAB. shouldn't be just to do with tyres and tread pattern.
Old 9th April 2008, 02:18 PM   #4 (permalink)
doggiehowser's Avatar
I think the tramlining was pretty bad initially. Seems to have smoothened out a little after abt 2000km on the clock.
And I do think tramlining has to do with the tyres. On my old Evo.. I changed from stock A046 tyres to semi slicks A048 (keeping same Ohlins suspension and geometry), the tramlining was very apparent.
doggiehowser is offline   Reply With Quote
Old 10th April 2008, 01:46 AM   #5 (permalink)
Beer Baron's Avatar
dino is right. tramlining is probably 70-80% down to tyre type and size. the wider the tyre the worse the tramlining. GTRs suffer this a lot as they generally run comparitively wide front tyres (usually a 255+ on 32s and up). it's also much worse with any type of 'performance' tyre.
one of my GTRs is a very track focussed R32. and even with it's very agressive suspension set-up the amount of tramlining varies a lot when I run on the A048s or the RE55s compared to my street tyre AD07s. suspension geometrey change may help a little, but mostly it's down to tyre size and type.
Beer Baron is offline   Reply With Quote
Old 10th April 2008, 01:48 AM   #6 (permalink)
tokyogtr's Avatar
so i guess once the tyres bed in more the tramlining will improve?
Old 10th April 2008, 02:05 AM   #7 (permalink)
DCD
DCD's Avatar
I think after your day at Fuji it will improve a bit.
Old 10th April 2008, 02:49 AM   #8 (permalink)
tokyogtr's Avatar
cool. still need to find out when the circuit mode function switches off after the trackday...
Old 10th April 2008, 03:28 AM   #9 (permalink)
DCD
DCD's Avatar
as soon as you leave the fuji grounds...
Old 10th April 2008, 03:44 AM   #10 (permalink)
tokyogtr's Avatar
i changed the location of the car to fuji but the circuit mode option did not enable. this sucks. it means on a really bas weather day that the car will not enable circuit mode even if you're at the circuit. f'ck this place p1sses me off sometimes.
Old 16th April 2008, 11:42 PM   #11 (permalink)
I have heard that the potenzas are mofos for tramlining. Something to do with the tread pattern as already mentioned. The Dunlops might be better in this regard.
timechaser is offline   Reply With Quote
