| Notices |
| View Poll Results: -7 or -5 turbos? | |||
| -5 for power - gimme gimme gimme! |
138 | 60.00% |
| -7 for spool-up - it's a street car after all! |
92 | 40.00% |
| Voters: 230. You may not vote on this poll | |||
#92 (permalink) | |
SamuraiSam
Lith, I have no information for you on the -9 turbos. I don't know anything about them, sorry.
#93 (permalink) | |
SamuraiSam
#94 (permalink) | |
SamuraiSam
It might "Feel" like it does - but it wouldn't. Absolutely no way in hell. Compare the two cars using quantitative analysis. The 0-60 on a GT-R will smoke the 0-60 on a Impreza. The Impreza has a tiny turbocharger with a super low boost threshold that 'feels' fast and falls on its face at about 5500rpm.
#95 (permalink) |
frostmotorsport
is working for a living... how boring!
Cars owned: '97 R33 GT-R, Evo 1 RS rally car, 3 Mk. II Escorts and many more!
you seem to have forgotten that roads (well, ones around here anyway) have corners.....
#97 (permalink) |
SamuraiSam
Hehe, correct.
Improper ignition timing=detonation. Detonation is when you have thousands of psi flame fronts colliding with each other. Uncontrllolled explosions generating many times over what std. combustion pressures are which is what kills engines and lifts heads.
#98 (permalink) | |
Lith
is lurking
That would probably have really high controlled cylinder pressures, on the turbo its running the average pressure throughout the rev range would be far more than a stock turbo'd EVO running 23psi. Decent head studs don't go amiss though, when dealing with high boost imho.
#99 (permalink) |
frostmotorsport
you make good points - except the ones about WRX's - I've owned and driven lots of fast cars and I'd take a good rex over a GTR anyday for a tight piece of tarmac. DOn't get me wrong, I love my GTR and they're a great car, but in the hands of someone skilled, a WRX is quite a weapon! no Evo but! but a weapon nonetheless.
If you want to be proved wrong, I'm happy to step up to the challenge! I have all 3 at my disposal right now!
#100 (permalink) |
frostmotorsport
in fact - in Glenns famous words .... do a search!!
any BMI/Option video/internet source will show GTR's struggling to keep up with AE86's / WRX's / Evo's / extrapolate that to a tight, twisty bit of B-road tarmac - you'd be chewing taillight!
#101 (permalink) |
Lith
is lurking
Thats why GTRs have been known to dominate in Targa NZ and Tasmania?
Anyway, was a bit of a wind up - I know where you are coming from. Its completely unrelated to the fact I'd go GT2560R-9s over GT2860-5s or -7s on a stockish RB26 which in itself is quite off topic haha
#102 (permalink) |
frostmotorsport
lets be honest tho... targa is not what I would call tight & twisty! care to explain why 2560's and not 2860's?
#103 (permalink) |
Lith
is lurking
Look at the compressor map of the GT2560s that I posted - or compare with
GT2560-9s: Compressor = 44.5mm inducer, 59.4mm exducer Turbine = 53.8mm inducer, 42mm exducer Compressor efficiency at 30lb/min = 75-6% from pressure ratio of 2-2.5bar GT2860-7s: Compressor = 44.5mm inducer, 60mm exducer Turbine = 53.8mm inducer, 42mm exducer Compressor efficiency at 30lb/min = varying between choke and 65% from pressure ratio of 2-2.5bar On paper the GT2560-9s have almost identical turbine and compressor sizes but has far better compressor efficiency in the areas that you'd want a nicely modified RB26DETT to be floating around in. In theory you should have no more lag, but the ability to both make more power - or the same power easier. See for yourself on Garretts own website: Garrett GT2560-9s Garrett GT2860-7s If it were me, I'd be looking seriously at the GT2560-9s unless you really want a high power thing. The GT2860R-5s can flow more than the GT2560R-9s but until you get up into the higher revs etc they have no major compressor efficiency advantage, and should give nothing away to the GT2860R-7s. I think they would easily give the best of both worlds.
