#46 (permalink) |
pupsi
is RIPs BUILT TWEENIEROB INSTALLED AND MAPPED.
Cars owned: GTR R33.
Which oil do you recommend for engine, gearbox and the diffs;
R33 GTR, RB30/26, Ported head, Tomei 280, 10.8 cams, T04z. Gearbox has the 1-5 close ratio O S Giken internals, triple plate clutch. Daily driver, fast road use, will be trying some trackdays. Its done about 500 miles since the total build, hopefully everythings bedded in nicely, so which fluids should I be keeping it topped up with?? I take it you do sell the engine oil in small barrels/drums?? Thanks.
#47 (permalink) |
oilman
GTR Register Trader
Cars owned: Mazda RX8
For the engine I would go with the Silkolene pro S 10w-50 or the Motul 300v 15w-50 here Opie Oils - Ester Synthetic
For the gearbox the Silkolene Syn5 75w-90 Silkolene SILKTRAN SYN 5 75W-90 Fully Synthetic Gear Oil Diff, the Silkolene BOA90ls Silkolene BOA 90 LS High Performance Gear And Limited Slip Differential Oil All of those are ideal. Cheers Guy
Use the code GTRR and get 10% Club Discount oilman's website: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. - register for news and offers email: To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. phone: 01209 202944 To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
#48 (permalink) |
edthemanjp
Cars owned: 1992 BNR32
Built RB26 running 25-27 PSI max. Mostly street use
I have seen your recommendations for ester based synthetics. I'm in America and on the Nico forums one of the techs displayed Nissans or Infinitis required oil for the G37, pictured below. This is going for 12-17 USD a quart. I'm currently running Mobil 1 15-50 synthetic and wondering about running Motul with or Nissans ester oil, I'm curios what your thoughts are on Nissans Ester. The tech also posted this link MOTUL ![]()
#49 (permalink) |
oilman
GTR Register Trader
Ester oils are where its at, to be honest I have never seen that nissan oil before, I am assuming its not available in the uk? Wouldnt mind giving it a test to see just how ester based it is.
You cannot go wrong with the Motul 300v if you can get it. Cheers Guy
#50 (permalink) |
Captain drift
is Haappy to have his car back
Cars owned: GTS-T NEO
Make : Rover
Model : 214 SLI Year : 1995 Engine size/type 1.4 K-series Any mods : None Type of use road Additional info: Currently used Halfords 10W40 What do you want a recommendation for? Engine. Daily driver, mainly in rush hour to commute to work, and short journeys Not a skyline but would still like a reccomendation. There is no one like you on the MG-rover.org site.
#51 (permalink) | |
oilman
GTR Register Trader
![]() 10w-40 semi is fine unless you wanted to treat it to 5w-40 fully, there are reasonably priced ones. Car Oils | Search by Brand, Type, Specification or Grade Cheers Simon
#53 (permalink) |
pupsi
Thanks for the info and recommendations. Will I be able to buy the said engine oil by the barrel/drum, at least 25 litres container, from you, thanks.
#54 (permalink) |
oilman
GTR Register Trader
Most of them come in 20 or 25ltr tubs, let me know which one you want.
Cheers Guy
#55 (permalink) |
Captain drift
Well your appreciated on here, Thank you
Halford recommend a mineral oil, 10W-40 is that better than semi- or fully?
#56 (permalink) | |
oilman
GTR Register Trader
10w-40 semis Fuchs or silkolene XTR 10w-40, 10w-40 oil, 10w40, 10w/40 Oil Products Shucks............thanks Cheers
#57 (permalink) |
wagzilla
is High maintenance!!!!
Cars owned: 1998 stagea 260rs 1957 chevy nomad 200 bmw 528it
Hi guy's I have a question ester oils we used them in airconditioning systems.....they now tell you not to use ester oil in air conditioning system now.....becouse of the way that easter dose not protect againest moisture?????
#59 (permalink) | |
oilman
GTR Register Trader
Cheers Guy
