Hi guys,
We had a customer after an aftermarket exhaust as he felt the stock wasn't loud enough...
No worries he came to the right place. He wanted the best money could buy, the best Japanese titanium
This is what a GT-R's exhaust will look like after next to no time on UK roads. Just like the Intercoolers the exhaust was made to a budget.
That's better
No photo's will do the Amuse exhaust justice, the quality of material, workmanship, welds are stunning. The kit also comes complete with new Nissan OEM gaskets and brackets, which isn't the case with some other brands.
The blue flame and gold rings maybe too extreme for some (like Nito) and there are variations available too.
The only thing that i feel personaly lets the Amuse down is its not loud enough ! (sorry i'm a lover of monster RB rumble) Even with straight pipe. But the sound on down blip is sexual.
Also decided to have a look at his ecu messages with the handy accessPORT
AWD
C1109
C1113
BCM
U1000
B2014
B2553
B2562
B2601
B2604
B2607
B260 a
B2612
B2617
MULTI AV
U1000 CAN
U1300
U1241
IPDM
B2109
His battery got too low, most of the codes talk about a bad connector, or the battery voltage getting to low.
Check engine light was not on, most these are all just historical codes that the different computer keep track of to help the dealership diagnose problems.
AWD
C1109
Battery Voltage Abnormal When the ABS actuator and electic unit (control
unit) power supply voltage is lower then normal.
possible cause:
Harness or connector,
ABS actuator and electric unit
Battery might have gotten low when the car was flashed.
C1113
G-SENSOR Decel malfunctioning.
Possible cause:
Harness or Connector
ABS actuator and electric unit.
yaw rate/side/decel G sensor
BCM
U1000
This is a CAN comms error
B2014
CHAIN OF S/L-BCM
Inactive communication between steering
lock unit and BCM
Possible cause
Harness or connectors
(Steering lock unit circuit is open or shorted) Steering lock unit BCM
B2553
B2562 LOW VOLTAGE When the power supply voltage to BCM remains less than 8.8 V for 120 seconds or more Harness or connector (power supply
circuit)
B2562
B2553 IGNITION RELAY
BCM detects a difference of signal for 2 seconds or more between the following information.
Ignition relay (fuse block) ON/OFF operation Ignition relay (fuse block) feedback.
(ignition relay feedback circuit is
open or short)
Fuse
Ignition relay
IPDM E/R
B2601
B2601 SHIFT POSITION
BCM detects when a difference between the shift P input signal and the shift position signal received from IPDM E/R via CAN communication continues for 2 seconds or more Harness or connectors (Control device circuit is open or
shorted)
Control device (detention switch)
B2604
B2604 PNP SW
BCM detects the following status for 500 ms or more when the ignition switch is in the ON position.
N position input signal exists. Shift position signal from TCM does not exist.
N position input signal does not exist. Shift position signal from TCM exists.
[TCM circuit is open or shorted]
TCM
BCM
B2607
B2607 S/L RELAY
BCM detects that there is a difference between the following statuses.
Steering lock unit ON signal transmitted by IPDM E/R The steering lock unit status feedback Harness or connectors (Steering lock unit power supply circuit is open or shorted) Steering lock relay (Built into IPDM
E/R)
B260 a
B260A IGNITION RELAY
Ignition relay (IPDM E/R) operation request Ignition relay feedback from IPDM E/R (CAN).
(Ignition relay operation circuit is
open or shorted.)
IPDM E/R
B2612
B2612 S/L STATUS
BCM detects the difference between
the following status for 1 second
Steering lock or unlock
Feedback of steering lock status from
IPDM E/R (CAN)
[Steering lock unit circuit (BCM side) is open or shorted] Harness or connectors [Steering lock unit circuit (IPDM E/R side) is open or shorted] Steering lock unit IPDM E/R BCM
B2617
B2617 STARTER RELAY
CIRC
An immediate operation of starter relay is requested by BCM, but there is no response for more than
1 second
(Starter relay circuit is open or shorted) IPDM E/R
MULTI AV
U1000 CAN
CAN coms error.
U1300
U1300 is indicated when malfunction occurs in communication signal of multi AV system. Indicated simultaneously, without fail, with the malfunction of control units connected to AV control unit with communication line.
U1241
IPDM
B2109
B2109 STRG LCK RELAY
OFF
IPDM E/R detects that the relay is stuck in the OFF position for about 1 second even if the IPDM E/R receives steering lock relay ON/OFF signal from BCM.
Harness or connector (Power supply
circuit)
IPDM E/R
Battery
Errors now fixed
