#16 (permalink) |
Lith
is lurking
Haha those Hondas aren't that bad aye, if the motor is built and tuned properly they are plenty reliable. The gearboxes are impressively strong, and one of the best things to aim for when going for cornering is low weight - Civics aren't exactly portly, helps for cornering, braking and accelerating as well as not eating brakes and tires as fast. Getting on the power coming out of corners is the main problem with a high power one like that, but it is achieveable.
Most of the time I hear the other way around, as heaps of people here use Hondas as track cars and often give mildly modified GTRs etc more than a run for their money around tracks - people usually talk down what would happen if the GTR and the Honda are put together side by side in a straight line. A mate of mine has a 500hp daily driven Civic, been running that power for a couple of years ago and has broken nothing using it for daily driving, track and drag. A 1.8litre engine in a sub 1100kg car is very tractible!
#18 (permalink) | |
mg1942
has no status.
What's amazing is the size of the Civic engine. Less tjhan 2 liters! And a 2.0 bar on GT-R would break the DSG. Did i forget to mention R-35's DSG costs more than that tuned civic? ![]()
#19 (permalink) | |
Phoenix
has no status.
The Honda weighs nothing, likely > 1000 lbs less weight and probably spins the front tires viciously through 1st and 2nd gear; wonder what kind of tires the Honda was using. I would hasten to guess the overtake speed (for the Honda) was probably well in excess of 100 mph. It's an OK win. Definitely a VERY fast Honda, but not a very user-friendly vehicle with those boost levels on a front-drive vehicle with that little mass.
#20 (permalink) | |
Phoenix
has no status.
Please show your math when stating that GT-R DSG $ > Civic + all modifications
#21 (permalink) |
Jspeed
has no status.
Cars owned: R35
Let me give you some inside info:
1st 2 runs:The GTR let the Civic start first and was way out of his power band at 2000+rpm 2nd gear and still lost by only 1/2 car length. If they had both started in 1st gear or 2nd gear in the GTR's powerband, the GTR would have won by a HUGE distance, hence they raced under such conditions. 3rd run: The GTR tried starting in 1st gear but revs were too high and he hit the rev limiter instantly while the Civic just pulled away. He tried to catch the Civic but gave up after 3rd gear. Facts: Civic never ran 2.0 bar of boost, was running 1.6 bar all the way. The GTR was on STOCK ECU but de-limited with Mine's exhaust. It for sure did not have the Mine's ECU if not would have probably won ![]()
#22 (permalink) |
Nismo-ace
has no status.
You also have to look at the money difference.........
That civic is probably less than £15,000 including mods and the skyline is around £60,000+ so you have to rate the civic. Although thats only in the straight line coming around corners like the other user said it'll probably lose with a big difference around a track. skyline gtr35 all th way!!!!!!!!
#23 (permalink) | |
Phoenix
has no status.
no 'launch control'??????? hmmm. why? I was wondering, because I can't imagine that Civic being able to gain any meaningful traction before 3rd gear from a stop. A lot of the time, especially with front-drive vehicles, 1.6 psi > 2.0 psi, so it is getting clearer now. I would probably try to modify to staged psi in different gears doing 50% in 1st and 2nd, 75% in 3rd and WOT after. Why did they say the GT-R was running with a Mine's ECU? The facts are definitely appreciated. I don't take anything away from the numbers the Honda is making, but it just can't deliver the power to the pavement. Sorry, just not possible.
#24 (permalink) |
Jspeed
has no status.
Cars owned: R35
[QUOTE=Phoenix;901974]appreciate the truth.
Why did they say the GT-R was running with a Mine's ECU? The facts are definitely appreciated. [QUOTE] I think they assumed cos most of the GTRs over here are running with the Mine's ECU, although most of them are on stock exhaust.
#25 (permalink) |
tokyogtr
is cobb'd
Cars owned: Nissan GT-R R35 with COBB AP and awesome map from Ben Linney @ GTC
what was the distance of this drag btw? any idea what the top speed of the civic is?
#27 (permalink) | |
KingAbarth
has no status.
anymore 'insider' info?? ![]()
#29 (permalink) |
KingAbarth
has no status.
of cos there are..
I think black accounts to the most while red the least.. back to the topic... any reason why they didnt do a stand still launch?
#30 (permalink) |
Jspeed
has no status.
Cars owned: R35
It was a friendly race to see how fast the Civic was after tuning. If they launched or even rolling started in 1st gear, the GTR would have won by bus lengths. However, I think the guy who put the video up has his own agenda or did not have the proper info
