Great. I'll assume you have an R32 GTR. Mine has no size indicated on the casting, does yours? Can I ask where you got the above info?
I've snooped areound a good Nissan dealer here and it seems the 1" is the std item, the 17/16" is for the GTR V-Spec R32s and R33s i.e. OEM Brembo equiped cars and the 15/16" is a 3 outlet unit for the N1 which did not have ABS (although I beleive it could be optioned). Seems strange that the N1 has a smaller BMC but perhaps that suits the non ABS set up better.
Does this match up with what you know to be true?
Cheers.
