#106 (permalink) |
I'm running the engine hard and never in a steady state - I'm either pulling, or engine braking. Sounds like I'm on a dyno, which I think is the point of driving this way.
Turns out the map I had before still works fine - a middle of the road tune. Of course, I've got on-board det cans and wideband. Rebuilding the AAC has seemed to make idle better (as in, what I punch in on the Power FC, the engine actually matches when it's warmed up) I rolled the rear fenders and added 5mm spacers. They help finish the car's appearance, I need to do the fronts now. |
#107 (permalink) | |
I ran in my BMW motorcycle the same way. Brand new, 0km - as soon as the engine was warm and the bike was handed over to me, I pulled away WOT to redline through the first four gears. Believe me, that's not what the manual said to do!! |
#109 (permalink) | |
Get the car on the dyno ![]() A couple of days ago we started a new built supra, with all possible mods. The car was actually hooked up to the Dynapack, ran it warm, did a few pulls, changed oil, then mapped the car. Engine didnt blow out one drop of oil, and it made almost 700 at the hubs. How is that for a run in ? hehe... |
#110 (permalink) |
car's going in this saturday for some preliminary dyno runs - mostly to finish fine tuning my full-boost map and get that 8000-9000 zone dialed in.
as mentioned in another thread, I had a fuel pump failure, but my failsafe system worked Car has 90% fueling capacity on one pump - good for a solid 1.2 bar.I have a suspicion that the holes needed to be drilled for oil return (for the Tomei baffle) aren't there. But it may just be the power of the Tomei oil pump. Anyways, sucking the sump dry is not a good thing, and my pump is on the lowest setting. The Accusump doesn't help in this situation - at redline, oil pressure falls to 6 bars (from 8 bars), but the Accusump is set to trigger at 4 bars. Teething problems. I hope to get them all out of the way quickly. Also I hope to get the last batch of photos of my build. |
#112 (permalink) |
not only is it 4 bar, but a steady 4 bar for 30-40 seconds - PLENTY of time to shut down!
I will take pictures of how I have mine installed - I went to a manual valve setup, so I can shut the Accusump off during city driving. |
#113 (permalink) | |
![]() Only thing that worries me is that if your pump fails or something else causes you to lose oil pressure at 8k rpm, wouldn't it be bad to have cold oil dumped into the engine? Obviously its going to be better than no oil at all, but its something I was thinking about |
#115 (permalink) |
True, its just as everyone knows you're never meant to cane an engine until the oil is upto temp which is what got me thinking
![]() I wonder if theres a way to hook up a switch that kills the ignition if it detects a lack of oil pressure |
#117 (permalink) |
none of my builder's hi-res pics, but some snapshots with my phone:
car back on the lift: ![]() 231km, and all innards disassembled yet again: ![]() Notice the Tomei oil pump - as any builder should, the pump was disassembled, the gears checked, and then the backing plate reinstalled with Loctite. Not many moving parts in an oil pump, and it's a quick five minute job to make sure a pump is working. Cosworth bearings check out as good to go: ![]() check out the bore hone, how it holds oil even a week after disassembly - makes the bores look like glass. ![]() all new idlers (old ones seemed ok but I'd rather not take chances), new steel grade 10.9 bolts, and the head is complete with replaced valves and valve guides. And just for the hell of it, I've decided to add a Trust sump extension. Although the Tomei sump extension would be ideal as it doesn't extend below the front subframe crossmember, it's also $2000, TEN TIMES the price of the Trust. So Trust it is And my oiling system now consists of: Tomei oil restrictor, Tomei oil baffle, Trust oil cooler, Trust oil extension, Canton Accusump. The whole thing will take ten liters of oil to fill, and so far as I can figure, is about as complete a wet sump system as one can do on an RB26. The only missing thing is the head drain mod - I'm not 100% sold on that, and I think the extended sump will make running the pan dry a near impossibility.Overkill, eh? ![]() |
#119 (permalink) | |
![]() better of wiring such a relay into the igition so the whole motor is cut - or even splice it into your coil loom earth so that just the ignition is cut! my 2p anyway... nice build KC! ![]() |
