#16 (permalink) |
It just failed on a shift up to third on boost. Box never crunched and drove sweet all the time. I have a new OS R3C tripple plate which doesnt have the sprung centre so it just shocked the box to pieces. 3RD is he most common gear to break anyway. I have been told that the center plate bends and the gears seperate so that they are only touching at the tips hence the mess.
#19 (permalink) |
Thats what I'm thinking mate. As the gears shouldn't break if they stayed aligned. I might give it a go and see what happens. I have been told that the Getrag out of the R34 doesn't normally break gears just syncros. SO that might be another option for me.
#24 (permalink) |
Well the main part i have been waiting for has turned up. Its the gearbox center plate. Made from Billit alloy so should stop the gears from seperating. Alot of people go down the uprated gear kit route but I thought i would test the stock gear set to destruction. :lol: I have heard that the OS giken gear sets still break 3rd. So i don't see the point in spending £2000 on parts for it to happen again when i can get my hands on stock gear sets for cheap. :lol:
This is an OS giken reinforced center plate that cost a fortune. :lol: ![]() ![]() ![]() I'm surposed to be at Abbey on Thursday to learn how to rebuilt the gear set onto my center plate but i have to go to see the pysio so not to sure i can make it yet. |
#27 (permalink) |
GTROC Member 666
Is it worth trying to cryo the gearset? Was flicking through Banzai yesterday and noticed they had a piece on it, seemed like a cheap way to strengthen your gearbox if you've already got it in bits.
#29 (permalink) |
oh whats cryo? I guess its a strengthening treatment.
The plate stops the twist and separating of the input shaft and lay shaft. Which in turn should stop it from stripping gears. Hopefully.. As i said going to try with stock gears as they will be alot cheaper to replace then OS gears if it does go bang again. |
#30 (permalink) | |
