Old 21st June 2008, 06:52 AM   #1 (permalink)
Vpro 2 step/launch control
Hello,
Not a gtr owner but do have a rb26 in an old school 240z using HKS Vpro.
My tuner is looking into it but i thought i would ask around to.
Is there a way to utilize the 2 step without having some kind of speed sensor???? I only want to use the 2 step at this point to build boost on a transbrake. So I'm wondering if you could use the actually trans brake circuit to control the 2 step?
Any help would be much appreciated
Stony
BTW here is a video off the car and motor. Its going to the dyno tomorro for final tune after a bottom end rebuild.
Stony is offline   Reply With Quote
Old 21st June 2008, 03:58 PM   #2 (permalink)
UK_SPAWN's Avatar
Send a message via MSN to UK_SPAWN
The engine is bigger than the car looking sweet
UK_SPAWN is offline   Reply With Quote
Old 1st July 2008, 02:32 AM   #3 (permalink)
Question still unanswered??? Is anyone using vpro 2 step???
Here is a video of the Z on the dyno
Old 1st July 2008, 03:24 AM   #4 (permalink)
GT-R Glenn's Avatar
I dont really know how it works so ........!
I would have thought a reed switch on the clutch pedal, but its an auto ...
So a reed / sensor on a front wheel hub maybe ?
Old 1st July 2008, 03:39 AM   #5 (permalink)
i run the VPro and use the 2step. but it's set on the speed sensor. i believe you can set it up on a button switch also. the tuner should have a HKS book with the break down of the VPro. tell him to read through it.
boostinvert is offline   Reply With Quote
Old 1st July 2008, 03:45 AM   #6 (permalink)
We know we can use a switch just trying to determine what kind it has to be.
Old 1st July 2008, 03:47 AM   #7 (permalink)
should be a push button style. like push it and hold it to use 2step. and release to disable it.
Old 1st July 2008, 03:49 AM   #8 (permalink)
Yea i was thinking the same thing and thinking the transbrake button should work but we will see.
Old 1st July 2008, 03:51 AM   #9 (permalink)
i would think it would work. if i get a chance in the next few days to look throught the book. i'll look at it and see if it would work.
Old 1st July 2008, 04:04 AM   #10 (permalink)
Thanks would help allot.
Eventually I will fab up a speed sensor for launch control just not interested in it right now... just need the 2 step to build boost on the line. And if it won’t work a recommendation on the type of switch that will work, would be much appreciated.
BTW the tuner had to go out of town so cant ask him I just wanted to get the parts on the way before he gets back.
Old 1st July 2008, 04:07 AM   #11 (permalink)
where are you located?
Old 1st July 2008, 04:08 AM   #12 (permalink)
Anchorage alaska
Old 1st July 2008, 04:11 AM   #13 (permalink)
ahh... well i will try and get by the shop and take a look at the book. i'll send you a pm or post in here when i get a chance to look it up
Old 1st July 2008, 04:13 AM   #14 (permalink)
Thanks again....
Old 1st July 2008, 04:13 AM   #15 (permalink)
no problem
