Old 14th July 2008, 11:52 PM   #1 (permalink)
GT-R Glenn's Avatar
Recirc Remove
For those interested.
Old 15th July 2008, 03:23 AM   #2 (permalink)
frostmotorsport's Avatar
nice. have considered this mod, however, one of my favorite noises that a GTR makes (and a big part of the reason I bought one) is the way the twin BOV's chatter to each other on mild-boost gearchanges!!
sad, I know.....
Old 15th July 2008, 10:57 AM   #3 (permalink)
Sub Boy's Avatar
does it vent to atmosphere Glenn? Are you still running AFM's?
Old 15th July 2008, 10:03 PM   #4 (permalink)
GT-R Glenn's Avatar
50mm Tial to atmos.
No AFM's
Yoda says its no problem to remove it all even if using AFM's.
Old 15th July 2008, 10:52 PM   #5 (permalink)
GT-R Glenn's Avatar
Ive redone the drawing to show in green the parts that you can remove and in red the parts that require blocking off.
Heres the Front turbo port blocked off
Heres the rear turbo port blocked off
The part inside the f/r guard cut and blanked
Position of BOV
How I fed the BOV
If you look at the vacuum supply to the bov, the 2 into 1 splitter was cut off the pipe inside the guard on the driver side ..This has been blanked off.
Very clever observers will notice that the "feed" off the vacuum box has 2 ports, this is where I had the D-Jetro take off from.
It was a miserable failure, so I used the 2 into 1 to feed bov, you can also see the new maf feeds in the position that they are supposed to be in.
Old 15th July 2008, 11:55 PM   #6 (permalink)
GT-R Glenn's Avatar
Test
Ignore please chaps.
Old 16th July 2008, 10:43 AM   #7 (permalink)
Sub Boy's Avatar
I had atmo BOVs on the car when I bought it....It was stalling at the lights and slugish between gear changes, switched all the pipes out and fitted std BOVs and fixed all probs.
...guessing your D-Jetro has no problem with it
Old 16th July 2008, 04:01 PM   #8 (permalink)
DaveV's Avatar
As one of my std BOVs has acquired a hole I now have all of the recirc pipework blocked off with barely any ill effects. I'm still running everything else standard.
It can bit a tiny bit jerky when you gently roll of the throttle at motorway speeds but that's all.
DaveV is offline   Reply With Quote
Old 16th July 2008, 07:16 PM   #9 (permalink)
rb30 710bhp
rockabilly's Avatar
Send a message via Yahoo to rockabilly
dave be careful you dont create too much back pressure on boost when you let off.if you are running ceramics there is a small chance you can shatter the impellers..just a thought.. also if you need two recirc std valves pm me. i have vent -to-atmo on but i run map sensors too.bernie
fancy the south of france.
http://st-tropez.mysite.orange.co.uk/
Old 16th July 2008, 07:22 PM   #10 (permalink)
DUNCAN GT-R's Avatar
Nice bit of welding on that front turbo port, although when i did that to mine, i suffered from alot of turbo shuffle, so i connected both turbo ports back together and it was much better.
Are you getting turbo shuffle with them blocked off ?
DUNCAN GT-R is offline   Reply With Quote
Old 16th July 2008, 08:57 PM   #11 (permalink)
GT-R Glenn's Avatar
I have never had turbo shuffle on my car / std / R581's /2530's turbo's.
Chris, no problem with d-jetro.
Yoda says the only difference is the standard bovs dont seal at idle ...
He is adamant you can remove it all even with pcf/afm type.
ps please excuse the steel parts not being painted ....lol
They will get done some time , but Im spending all my time on the other one right now.
Old 17th July 2008, 11:46 AM   #12 (permalink)
Alecci's Avatar
Interesting... I've gone for VTA BOV's myself, and I'm experiencing what some refer to as 'turbo shuffle' or 'swirwel effect'. Someone suggested using a balance tube between the ports on the inlet tubes. Any thoughts?
Another thing I'm curious about when blocking the ports completely, what do you do with the vacuum line going into the standard 3-way balance tube? The other part of that vacuum line, according to the vacuum diagrammes I've seen, runs to the boost solenoid?
Alecci is offline   Reply With Quote
Old 17th July 2008, 12:04 PM   #13 (permalink)
Sub Boy's Avatar
I had twin turbosmarts and my pipes looked exactly like yours when I got the car, and with both the std comp and the pfc, the stalling was there. Will oneday switch to an R-Type BOV but will retain the plumb back unless I go to a MAP system.
Car goes in for it's Tomei cams and splitfire coils/dyno tune soon.
Old 17th July 2008, 09:38 PM   #14 (permalink)
GT-R Glenn's Avatar
If the 3 way thing is the "twin turbo" pipe, I tig'd a fitting on there ,dont run any factory boost stuff.
Alecci are you running afm's ?
Chris, I dont know,If its stalling you can adjust all that with the pfc.
Yoda says the factory setup doesnt seal at idle,which is why you need to reset all the idle control when you take it off , was it running pcf with recirc off ?
Old 17th July 2008, 09:44 PM   #15 (permalink)
Alecci's Avatar
GT-R Glenn, I'm running AFM's for now but have ordered a D-Jetro and waiting for it to arrive.
The 3-way tube is the one to the far right on the 3rd picture from the top in the first post, or in the centre of the first pic on the #5 post on this thread.
Towards the port of the rear turbo on this 3-way tube (or actually on an air hose connected to it) is a nipple which connects to one of the two vacuum lines coming 'round the back side of the engine (the other one leading from the wastegates to the solenoid via the intake plenum).
