Old 22nd July 2008, 11:15 PM   #16 (permalink)
paul cawson's Avatar
Originally Posted by Madden View Post
Good stuff Pual. I was told max of 9.8mm before head mods. I didn't know you have to pocket the pistons **** that. I would just put a couple of headgaskets on
My 10.05 cams just clip the side of the follower bore so I think 9.8 would be good to fit with no head mods. Again with a 1.5 head gasket you should be ok for valve to piston clearance, if the block and head have not being skimmed. But to be certain and without removing the head its best to stick with 9.2 lift
I got those 280 9.15mm cams for £230 so just waiting on delivery. What effects would changing the cam timing have on the performance? i.e advance and retard the inlet or exhuast cam?
All you can do is book a dyno as there are so many variables, it would be best to check AFR and exhaust temps if possible.
Old 23rd July 2008, 02:45 AM   #17 (permalink)
Madden's Avatar
I will let you guys know how i get on. I have graphs and figures from before so i will dyno again to see what it makes after the cams and my own remap.
