Old 20th July 2008, 04:53 PM   #1 (permalink)
gibson's Avatar
cometic,acl, headgasket issues??
looking at both of these gaskets toward number six there is a rivet on the multi layer gaskets that holds the layers together it seems to me that the rivet by No 6 hits the surface of the head on both ACL and Cometic gaskets is this normal???, I see it as a gasket failure waiting to happen.
Any opinions
gibson is offline   Reply With Quote
Old 20th July 2008, 05:14 PM   #2 (permalink)
Madden's Avatar
There was a thead on here about the cometic gaskets sealing less the the stock items. It was done on a test by a guy in Japan. It didn't bring up your rivit problem.
Do a search.
I have an old cometic gasket here i can check if you want?
1ST PRO/STREET DRAG SERIES ROUND ONE (12.3-13.3)
1ST PRO/STREET DRAG SERIES ROUND TWO (11.3-12.3)
NEW PB 11.3 @121MPH
Old 20th July 2008, 05:30 PM   #3 (permalink)
gibson's Avatar
hi Madden thanks for the info.. did do a search but couldn't find any info will try again.
Old 20th July 2008, 05:36 PM   #4 (permalink)
Madden's Avatar
I will have a look for ou mate.
NEW PB 11.3 @121MPH
Old 20th July 2008, 05:41 PM   #5 (permalink)
Madden's Avatar
Here you go mate. I couldn't find it on here so went to google.
Beyond The Dyno » All Head Gaskets are Not Created Equal
NEW PB 11.3 @121MPH
Old 20th July 2008, 05:55 PM   #6 (permalink)
gibson's Avatar
ok xs engineering ... thanks again Madden been looking on here from my last post.
They cover the compression seal or cylinder ring and slate another brand (not good business.. but any way) my problem (i think )is the rivet locations on both the above gaskets..i may just go standard Nissan gasket and oring the block.
Old 20th July 2008, 05:56 PM   #7 (permalink)
Andy W's Avatar
it will touch on the head, but there isn't anything for it to touch on the block, it isn't compressed between the 2
lay it on a block you'll see what i mean
bovered me, do i look bovered, bovered , no
AA join here
Andy W is offline   Reply With Quote
Old 20th July 2008, 06:02 PM   #8 (permalink)
Madden's Avatar
I know alot of peole run the cometics with no problems what so ever. So you should be fine.
NEW PB 11.3 @121MPH
Old 20th July 2008, 06:47 PM   #9 (permalink)
gibson's Avatar
Andy W i have checked that on the block .. the interesting thing is that when all bolted down the rivet makes an indent in the head surface suggesting that there is some compression on the rivet or am i just being OTT on this one.
Old 20th July 2008, 07:41 PM   #10 (permalink)
I run a cometic and i noticed the rivet but then it's like Andy says and it works fine for me.
r32gtr
HenrikE is offline   Reply With Quote
Old 20th July 2008, 10:22 PM   #11 (permalink)
gibson's Avatar
thanks for all replies
Old 30th July 2008, 11:48 AM   #12 (permalink)
Take the rivet out if it really bugs you, it's only their to stop the things separating in transit.
Best Regards,
Chris Wilson.
Old 31st July 2008, 09:06 AM   #13 (permalink)
gibson's Avatar
That was my conclusion also
RB30 short blocks, bosch fuel pumps and sensors Nolathane and Noltec Suspension components and bushings
www.nolathane.com.au
www.noltecsuspension.com
