Old 22nd July 2008, 01:52 PM   #1 (permalink)
Ian C's Avatar
Denso High impedance 550cc injectors on RB26
Right chaps,
looks like i may have been sold a dud....
Bought a set of Denso 550 cc injectors (195500-2020) on the understanding they run on the RB26DETT - turns out (from a quick search on here) they are for the RB25DET (non-neo)
Impedance (looking at the web) looks like 13.7, which i think is way over the spec of the direct replacement parts!
So, can I run them on my car at all, or are they going up for sale?
Can I use the RB25 injector resistor?
Anything I can change on my Apexi power FC PRO to make them run?
Thanks,
Ian
Ian C is offline   Reply With Quote
Old 22nd July 2008, 05:16 PM   #2 (permalink)
They will work but you have to bypass the factory injector resistors, I dont have a pic on me, maybe someone here does.
The factory gtr injectors are low impedance, but there is a resistor box in parallel with each injector to bring the impedance up. If you remove it and just hook up the injectors directly you should be fine.
Im not 100% sure on this, but i think you can just cut the resistor box off about 30mm long, strip all the wires and put a crimp lug on them and this will do the trick.
fletch.rb30 is offline   Reply With Quote
Old 22nd July 2008, 06:32 PM   #3 (permalink)
Ian C's Avatar
If i have to butcher the loom then i don't fancy it - may as well just do it properly...So these are going up for sale!
thanks for the help!
Ian
