What max power on std RB26 internals
In not looking for your thoughts on limits but I want to know how far anyone has gone on std internals, i.e. block, rods, pistons and crank.
Paul H |
HardcoRe GTROC Member
from that list Paul, i would say the pistons will be your weak point at anywhere between 500 and 600hp.
Ben スミグズ My GTR Development Thread - Team QM1 GTROC North West Regional Rep Life is not a journey to the grave with the goal of arriving safely in a prettily preserved body, but rather to skid in sideways in a shower of gravel and party shards - thoroughly used, utterly exhausted and loudly proclaiming "f**k me, that was brilliant!!" |
i read somewhere that 700 had been achieved several times, big enough turbo(s) and a conservative map was fine.
White R33 GTR Quietly building something special......shhhh Then breaking it again...... Then building it again!! woo! |
Hopefully i'll be about 550 - 580 on standard internals soon.....
I had a 33 that was running 470 atw as a track car and my 34 has been at 490 atw with loads of abuse, Im just keen to see if that could be increased with some degree of reliability
Paul H |
Have a look with Search - it's been covered many times on here and there are lots of perspectives on this one.
Howsie "A liberal is a person whose interests aren't at stake at the moment." |
#8 (permalink) | |
Have you used this first ? Search 1 Bar = 14.7 lb .1mm = 004" 1 kw = 1.34 hp RPM x Tire Diameter (ins) --------------------------------- = MPH Diff Ratio x 336 |
Haven't RIP built some very high power engines on stock internals? Try asking them.
From memory they say the standard internals can handle loads of power if the mapping is correct, in excess of 600whp. Sure a search will find the thread. Cheers, |
Some guys claim over 1000hp on stock pistons but we have only been to about 750 and 7200rpm.
I find it very hard to believe people break stock pistons at 600-800hp and reasonable rpm due to "outright power", I would almost guarantee the failer was a result of a tuning issue and I bet most of them had cracked ring lands not a piston broken in 1/2 through the gudgeon pin hole. Rob
#12 (permalink) |
hi i have had 648hp+513lb/ft on standard engine.unfortunately now it is bust due to the belt failing on the way home just at 70 from the pod in may.it ran for 8 months fine until then so it is possible for power on stock engines.waiting for a new lump now.
#13 (permalink) | |
what mods did you have to get that power ?
32gtr what else do i need to say ! |
#14 (permalink) |
mods
Standard Nissan Bodywork
Nismo Exhaust System TRUST T88-33D turbine TRUST stainless steel EX manifold TRUST racing waste gate TRUST front pipe HKS camshafts TRUST cam sprocket NISMO bulk fuel pump NISMO 720cc injector The nissan infinity 90 pie throttle NISMO fuel pressure regulator TRUST 3 layer type intercooler TRUST intercooler pipe TRUST suction pipe TRUST OIL cooler ENDLESS BIG surge tank ARC titanium radiator panel SAMCO KIT ENDLESS oil catch tank TRUST air lynx x2 Z32 Air flow Meters x2 ENDLESS 3 layer type radiator HKS F-CON V-PRO gold HKS triple plate clutch BLITZ DUAL-SBC boost controller BILLION VFC variable fan controller HKS hyper MAX-II height pitch HKS turbo timer HKS boost meter DEFI LINK meter exhaust warm burning pressure (inside glove compartment) PROJECTµ brake pad the car was from global auto. |
