Cam timing?
Hello, i fitted RB26dett stock cams to my rb25det engine, i now have a problem with compressions.(5.5-5.8bar in all cylinders) I also used rb26 cam gears. Would it be possible that the cam timing is wrong, the markings match.
So you are using solid lift camshafts in a hydraulic lifter head, are you still using the hydraulic lifters as well? In my experience you can't swap camshafts.
GTR the badge all V8 boys fear!!! Hytech Engines Street R32 GTR - 10.86 @ 130mph (209kph) www.hytechengines.co.nz |
i looked up, that rb26 and 26 cams have different timing, even different years of rb25 and 26 have different timing.
First, to prove my theory i lifted the intake cam 1 tooth later and exhaust cam 1 tooth earlier. It worked, compressions raised from 5.5 to 9.5-10bar. Then i fitted adjustable cams to fine tune and now the compressions are 11.5-12.0 all around. Lookes like you can use rb26 cams in 25 head with hydraulic lifters. Tomorrow i´m off to dyno and hoping for something around 600hp. |
