Old 26th July 2008, 03:35 AM   #1 (permalink)
n boost's Avatar
1 bar boost afr's on stock ecu..rich or lean
What afr' do gtr r33 nomally run @1 bar on stock ecu?
Checked mine with my lm-2 and am getting low 12's 4-6000 rpm range and 11.6/5 between 6-8000 rpm.
I thought gtr normally run rich at 1 bar. I think i might have a remapped ecu if they are supposed to run rich but there are no stickers on the ecu and car was virtually stock when i bought it.
Would u guys consider low to mid 12's as lean if you got no det and running on 99 oct v-power?
n boost is offline   Reply With Quote
Old 26th July 2008, 07:04 AM   #2 (permalink)
Steve@React's Avatar
That is running rich, lower than 14.7:1 (stoichiometric) is rich & anything higher than that is lean
As far as I know the stock ECU will run 1 bar but will over fuel like mad, that's why you can see some large power/torque improvements after a dedicated remap.
Steve@React is offline   Reply With Quote
Old 26th July 2008, 02:09 PM   #3 (permalink)
n boost's Avatar
At full load if i was in the high 10's then i would consider that to be rich but obviously i am getting low/mid 12's under boost midrange and only dips into mid 11's after 6k rpm which i consider to be bordeline on the lean side and idle is 15.2/3 afr.
so am just trying to find out if this is normal for a stock ecu as my deffo aint overfuelling.
Trying to justify a remap but if afr's are acceptable and no det then how much extra hp can i gain and also my stock injectors are at 85% duty cycle so not much left in them.
Old 26th July 2008, 02:23 PM   #4 (permalink)
Sidious's Avatar
The fueling is perfect for a turbo car, leave it well alone, the ECU map on the RB26 and a few other Japanese turbocharged cars were setup to work best on 100 RON petrol even on stock boost.
It is not uncommon for other turbo cars run ratios of 10:1 and under with stock configuration as the RPMS rise.
Sidious is offline   Reply With Quote
Old 26th July 2008, 05:46 PM   #5 (permalink)
UKPAISLEY's Avatar
The a/r is ok, its the ig time and the Knock I would be worried about.
Old 26th July 2008, 07:34 PM   #6 (permalink)
n boost's Avatar
That's what i thought but wanted to make sure. If i richened the mixture then i would probably lose some hp as well, so reckon if it is safe at this afr then i will leave it alone.
i know some people run mid to high 12 afrs without any probs but uk cars are mainly mapped around the low to mid 11's on full boost.
I didn't pick up any det so should be o.k, but will double check for knock.
