Old 26th July 2008, 01:49 PM   #1 (permalink)
Asim R32GTR's Avatar
Single throttlebody vs multi / stock?
Hi
I did a search, but could not find a good answer for this.
I have a R32GTR, it is still running stock multi throttlebody`s.
Has anyone got first hand experience with conversion to single throttlebody?
Did it make much difference?
Are the stock ones restrictive?
etc..
My car is going on the dyno on Wednesday, i need to decide which plenum to use, since i have both available.
Thanks
Asim
Old 26th July 2008, 06:00 PM   #2 (permalink)
palmer77's Avatar
i believe the multi ones give better response......
palmer77 is offline   Reply With Quote
Old 26th July 2008, 06:38 PM   #3 (permalink)
Madden's Avatar
Rk tuning runs standard throttle bodies on his cars. They must be good.
1ST PRO/STREET DRAG SERIES ROUND ONE (12.3-13.3)
1ST PRO/STREET DRAG SERIES ROUND TWO (11.3-12.3)
NEW PB 11.3 @121MPH
Old 26th July 2008, 07:43 PM   #4 (permalink)
andreasgtr's Avatar
Send a message via ICQ to andreasgtr
Rain runs a single one on his R32. I think it is because you can't get bigger diameter intake plenums with stock throttles. So bigger plenums with higher flow capacity have a single throttle body.
But that's just my try to explain it.
andreasgtr is offline   Reply With Quote
Old 26th July 2008, 07:47 PM   #5 (permalink)
Stachi's Avatar
I'm with you on this Andreas.. Would be way to much work to make bigger single throttles and imo wouldn't make that much difference on big power applications.
BTW, have you gone for NOS yet, as advertised on the other forum? :P
Marc
Old 26th July 2008, 10:11 PM   #6 (permalink)
lightspeed's Avatar
You can bore out the stock 45mm throttles for either 48 or 50mm throttles.
You can also machine the spindle to have flat sides.
The other mod is PTFE washers to stop the shaft seals blowing out with high boost. Reinik make these.
Old 26th July 2008, 10:23 PM   #7 (permalink)
Madden's Avatar
When should you upgrade to ported or big single throttle bodies?
NEW PB 11.3 @121MPH
Old 26th July 2008, 10:47 PM   #8 (permalink)
GT-R Glenn's Avatar
Standard ones are a serious piece of work do not underestimate hpw good rb26 parts are.
Except the oil pump drive....
When you make over 1000 hp
Have you used this first ?
Search
1 Bar = 14.7 lb
.1mm = 004"
1 kw = 1.34 hp
RPM x Tire Diameter (ins)
--------------------------------- = MPH
Diff Ratio x 336
Old 26th July 2008, 10:58 PM   #9 (permalink)
paul cawson's Avatar
RK never changed his plenum even when he ran 9s, but the throttles were over sized.
"I am clever because I know the cause of my ignorance..." ~ Bruce Lee
paul cawson is online now   Reply With Quote
Old 26th July 2008, 11:05 PM   #10 (permalink)
Madden's Avatar
Sounds good to me
NEW PB 11.3 @121MPH
Old 29th July 2008, 09:35 AM   #11 (permalink)
Advantage of single throttle body is that you can ditch the standard airflow meters and run an aftermarket ECU with a MAP sensor. A single throttle can be made absolutely huge, so any real or imagined flow restriction of the multi throttles will be eliminated. The big plenum volume behind the single throttle damps out the worst of the pressure pulsing, so a MAP sensor at least has a fighting chance of indicating engine load.
There is another aspect to all this as well. Multi throttles are much more cam friendly. If you are running extreme cams, multi throttles will idle smoother and run cleaner and be less lumpy at part throttle lowish rpm.
Multi throttles can cause diabolical problems tuning a MAP based system at small throttle openings, if you are going aftermarket ECU, that uses a MAP sensor, a single throttle will give much better and more stable part throttle mixtures, and as a result, quite likely the potential for much better part throttle fuel economy in a road car.
A single throttle is very popular among the drag racing crowd, but the big disadvantage is throttle response. If you are a drag racer the throttle has only two positions anyway, so who cares about throttle response?
The circuit racers sure do !!!
Try nursing a GTR around a wet race track at full racing speed right on the limit of adhesion. You are driving on the throttle, and you want crisp instant part throttle response, or you are going to go off the track, or be the last car in the pack.
The serious circuit race cars NEVER fit single throttles. The drag racers mostly do. What are you going to use YOUR car for ?
So basically there are several quite different things to think about, mostly depending on how you plan to use your car.
Top end airflow
Throttle response and drivability
Idle quality and lumpiness with big cams.
Compatibility with the ECU, (flow meters or MAP sensor)
Part throttle mixture control and part throttle fuel economy.
Decide what is most important to you and modify accordingly.
Cheers, Tony
Warpspeed is offline   Reply With Quote
Old 29th July 2008, 09:58 AM   #12 (permalink)
One last thought on all this.
The cam friendly part of having multi throttles is why a GTR engine can pass strict emissions testing without using variable inlet cam timing. The single throttle RB25DE(T) cannot get away with it. Variable inlet timing is there for passing emissions, and no other reason. It is certainly not a power enhancer.
Variable valve timing does nothing for power, which is why the GTR never had it.
So before you bin the multi throttles, realize that if you plan to run big cams the engine is going to be rougher and lumpier and be a lot more unhappy at idle because of increased exhaust reversion.
Cheers, Tony
Old 29th July 2008, 12:48 PM   #13 (permalink)
tarmac terror's Avatar
AT LAST!! some decent info...
Nice one mate.
TT
R32 GTR - With so many added goodies I cant be bothered to list them all :-)
E46 M3 SMG conv with ACS goodies.
Old 29th July 2008, 10:27 PM   #14 (permalink)
SamuraiSam's Avatar
The stock ITBs give far better throttle response than a single throttle. Just go to google and type in ITB to read about the advantages.
Resident Forum Asshole
Old 29th July 2008, 10:57 PM   #15 (permalink)
Warpspeed:
Thanks for the info mate, exactly what i was looking for
Decided to keep stock throttle bodys!
Asim
