I was cruising around reykjavik..finding cool places to take pictures of my gtr tonight and after that I was going home and had to stop on a red light and I was first car on red light so when the green light comes I take off (not so rough but a little bit rough) and then I noticed the front wheel drive isnt working...but there is no oil leaking or "clunk sound",no warning lights in the dashboard or anything that says something is broken...
maybe someone has explaination how this works and what might be the problem? I checked fluid on the tank in the boot and I grabbed both front axles and the drive shaft from the gearbox to the front diff and everything is okay. is there any motor that turnes the fwd on or something that could have died? or is there anything in the transfer box that could have got broken? and am I allowed to drive the car like this? I hope its nothing too big... regards, Teitur Yngvi
Teitur Yngvi BNR32 ´94 Clio MK1 1,4 ´97 Trek navigator 2.0 ´08 Last edited by Dohc; 26th July 2008 at 10:59 PM. |
how do you know the fronts aren't working? To test for sure, put the car on a lift, then at idle, put the car in 1st gear. With all four wheels in the air, the car should go into 4WD mode instantly.
Try bleeding the ATTESA system also, there may be air trapped in it.
1991 BNR32 2007 BMW F800S 1999 Suzuki Hayabusa stage one turbo (not running yet) 2009 Mercedes-Benz B200 Turbo (ordered) 2010 BMW S1000RR (first deposit in Korea placed) There are only three true sports: mountain climbing, auto racing, and bullfighting. Everything else is merely a game. |
#3 (permalink) | |
and it was spinning only on the rear... :S But I went out later tonight to check and the 4wd is working now..but I dont know what happend at all... :S very very strange.
Teitur Yngvi BNR32 ´94 Clio MK1 1,4 ´97 Trek navigator 2.0 ´08 |
I'm pretty sure this happened to me once - an isolated incident. Just one of those things
Im going to check again today if this is still okay.
a friend of mine is going to let me use his lift and lift the car up to double check axles and driveshaft.
my guess is it was just a computer glitch...I think if I search hard enough, I can even dig up the thread where I panicked
I checked today again and the front diff is broken...
but I can take it from the engine I had in it before. Shouldn´t be that much of a problem I think...or does it?
#11 (permalink) | |
but I have made some launches before and maybe it just got broken this time even tho I wasnt launching...but just enough to break it :S shit happends...I will post up pics when I get the time to repair ![]() I had to cancel alot of things I was going to do because of this :S but now I can clean the engine bay much better than I did last time and maybe get it resprayed before putting the engine in again...do this more pro this time.
