View Poll Results: Your dream Engine
RB28 112 23.43%
RB30 167 34.94%
TOMEI 75 15.69%
JUN 69 14.44%
Top Secret 127 26.57%
NISMO 73 15.27%
Big Single 72 15.06%
Twins 162 33.89%
Gas 66 13.81%
No Gas 61 12.76%
Multiple Choice Poll. Voters: 478. You may not vote on this poll
Old 18th February 2005, 09:13 AM   #16 (permalink)
SkylineUSA's Avatar
Send a message via AIM to SkylineUSA
426 Hemi Aluminum stroked to an 8 liter, with twin GT42s. That would be my engine if money was no limit!
With a huge 290*, 12mm lift cam 117lsa
With a progressive dual 300 shot fogger system.
Should have well over 2000hp, going through a Lenco Auto
SkylineUSA is offline   Reply With Quote
Old 18th February 2005, 08:43 PM   #17 (permalink)
Originally Posted by Hugh Keir
OS Giken 3 litre bottom end to give reasonable off boost torque and 9000 RPM capability.
Between 260° and 280° cams depending on whether you want the emphasis on torque or BHP. Cam lift between 9.5 and 10.8 for road / track, a bit more for drag only.
HKS GT-RS or HKS 2835 or HKS 3037S twins depending on whether you want the emphasis on torque ( 500 + ft lbs ) or power ( 700 to 900 BHP).
A quality tuner to set it up and maintain it.
Motec is my poison for bigger BHP.
You missed one very important category a sequential gearbox linked to the ECU to allow full throttle gearchanges.
It doesn't get much better than that.
That sounds pretty much like your car Hugh
Hamish is offline   Reply With Quote
Old 18th February 2005, 11:52 PM   #18 (permalink)
Tattooman's Avatar
Just give me all of them any of them will do just as long as it Flies......
Tattooman is offline   Reply With Quote
Old 19th February 2005, 07:11 PM   #19 (permalink)
Hugh Keir's Avatar
Philip,
High lift cams are a strain on the cam belt and the cam gear and are therefore not particularly suited to low RPM idle or to higher mileage by prolonged road use.
Hamish,
10 out of 10
For out and out driveability the GT-RS set up was fantastic with 2 bar of boost at just over 5000 RPM all the way to the redline.
The 3037S turbos with slightly bigger cams ( 280° by 10.8mm lift ) is less driveable but the hit with those turbos at 2 bar of boost is unbelievable.
I have some 1580cc injectors going in next month and will allow more boost which I am really looking forward to.
Hugh
Old 20th February 2005, 07:37 PM   #20 (permalink)
blueskygtr's Avatar
Hugh
RB2.8 Tomei built with GT Rs' Omex management OS sequential straight cut box
Pretty much the daddy of what i have got on the way!
Will have the Rs' mid summer hopefully finances allowing
blueskygtr is offline   Reply With Quote
Old 20th February 2005, 07:41 PM   #21 (permalink)
GTROC Chairman
Fuggles's Avatar
Send a message via MSN to Fuggles
I already have the build I want.
................. and believe me money is an object!
GTROC chairman
Please feel free to contact me with any GTROC questions
send an email to info@gtr.co.uk or send a PM
Fuggles is offline   Reply With Quote
Old 20th February 2005, 10:29 PM   #22 (permalink)
Banned
keith's Avatar
The OS Giken sequential gearbox is not straight cut
Keith
keith is offline   Reply With Quote
Old 20th February 2005, 11:42 PM   #23 (permalink)
blueskygtr's Avatar
Keith
But if money were no object then i would get them to make one for me
JAY
Old 22nd February 2005, 09:24 AM   #24 (permalink)
360/PS3: TrevSkyline
Trev's Avatar
Top Secret spec as the `33GTR that did 205mph through the tunnel in Tokyo
12.7 @ 116 mph, Santa Pod May 2005
Old 22nd February 2005, 01:15 PM   #25 (permalink)
240K-GT's Avatar
Send a message via MSN to 240K-GT Send a message via Yahoo to 240K-GT
Well I can't select any of the above in the poll really so here goes anyway:
If it was a mark 3 or 4 GTR it would be a fully race prep S20 engine, even down to the £1000 oil drive kit. MMM even more straight cut gear noise. Would be built buy one of the guys PS30-SB knows back in Japland.
If it was my Skyline then it would have to be something stupid like an L32 stroker with an OS Giken head on running my trust twin turbo kit but with some TD06-25G Turbo’s on instead, with a HKS Turbo surge tank on 3 double t/b's. Probably running a Motec ECU.
Ok that combination probably wont work or anything and will no doubt blow up :S
O I just thought the turbo kit and surge tank wont fit as a different head layout so will just get them build custom ones to look the same, but I think you get my stupid idea anyway.
Total cost a good £50K I bet for something that probably won’t work. Unless its all forged titanium or something like that ??
Will
240K-GT is offline   Reply With Quote
Old 22nd February 2005, 05:00 PM   #26 (permalink)
R32 Combat's Avatar
In my dreams it order a
RB26 block
Ti rods
Steel crank
Anodized forged pistons
Ti valves and valve gear
280deg 11.35 cams
Replace the timing belt with gears(not a chain)
Single trottle body(100mm)
T51r BB
Xtrac 6speed straight cut 'fly by wire' sequential
OS clutch
Prodrive ECU
God knows what it would be like.
Old 23rd February 2005, 12:08 AM   #27 (permalink)
ming's Avatar
Wink dreams
rb30
top secret
big twins
vpro
ming is offline   Reply With Quote
Old 4th March 2005, 02:30 PM   #28 (permalink)
Gibson Motorsport Engine+ HKS 3037 S Prox2 +Holinger box
silverzilla is offline   Reply With Quote
Old 5th March 2005, 10:52 PM   #29 (permalink)
paul cawson's Avatar
My dream RB 2.7 2540 @ 1.2 bar Gas of course! Roll on the good weather Tried a test on private land ended up doing a 180 !
Old 6th March 2005, 05:38 PM   #30 (permalink)
JasonO's Avatar
Send a message via ICQ to JasonO Send a message via MSN to JasonO
Originally Posted by SteveN
Tho i think itd just be me n you (-C-) backed into a corner beating off hordes of angry sheep with sticks tho, lol
I'd be there too, in the corner, sporting a big bag of left over bits from my RB25 project.
Expired....
[E&OE.....]
JasonO is offline   Reply With Quote
