| View Poll Results: Your dream Engine | |||
| RB28 |
105 | 23.13% |
| RB30 |
158 | 34.80% |
| TOMEI |
72 | 15.86% |
| JUN |
66 | 14.54% |
| Top Secret |
122 | 26.87% |
| NISMO |
70 | 15.42% |
| Big Single |
70 | 15.42% |
| Twins |
155 | 34.14% |
| Gas |
65 | 14.32% |
| No Gas |
60 | 13.22% |
| Multiple Choice Poll. Voters: 454. You may not vote on this poll | |||
#47 (permalink) | |
...and at big revs; they're fatal. Mario. |
#49 (permalink) |
At big revs the oil pump is moving a lot of oil though the motor. The higher the revs, the more oil.
You suck all the oil out of the pan, run dry and spin a bearing. What I have seen anyway. I would be interested to look into a motor spinning big revs and spraying oil at the underside of the piston. I noticed Cadiliac is even putting oil squirters in their supercharged Northstar motor. They say its worth torque and horsepower due to their ability to run more advance. |
#50 (permalink) |
I suppose lack of oil could be an issue if running mega rev's like Mario (11,000???) But upto 9500 or so i think with adequate mods to the oiling system and an increased capacity sump it isn't a problem.
Mind you this is an "ulitmate engine" thread so you probably will all want to be running 12,000rpm ![]() |
#51 (permalink) |
An "ultimate" engine will be dry sumped, anyway. The best ultimate engines are the ones you build for someone else, spending their money and making a profit on it
Best Regards, Chris Wilson. |
#52 (permalink) |
This is One I bid on last week. I was saved from buying it by the vehicle inspector because of engine noise.
They now know to buy in any condition if the car of the right spec comes up. Sad story, very sad if you read Japanese.http://uk.pg.photos.yahoo.com/ph/pau...bum?.dir=/5e6b
"I am clever because I know the cause of my ignorance..." ~ Bruce Lee |
#53 (permalink) |
Paul,
That looks like it was quite a car, what auction was it sold at? Thanks Hugh
RB30 - Sequential Gearbox - Acceleration Demo Video TOTB II ¼ mile Drag Shootout champion. TOTB IV 4th TOP speed @193.8 MPH. TOTB 6 10.3 @ 150 MPH ¼ mile 194 MPH at 1 mile Shakespeare County Raceway 10.120 ¼ mile RB Motorsport Built OS Giken 3 litre engine and OS Giken sequential gearbox. Twin HKS 3037S turbos 480 BHP ea. Motec M600 ECU. |
#55 (permalink) |
Paul,
I can look back at cars sold at HAA Kopbe and it doesn't look like it was there, the auction sheet is also slightly different at HAA to the one you posted. I can't look back at the USS auctions. There is no power steereing and no electric windows, it looks like it was a drag oinly car. How much did it sell for?
#56 (permalink) |
Absolutely no cost limit? Okay...
Engine designation: Nissan RB26DETT: 2.6 litre, Double overhead cam, Electronic fuel injection, Twin Turbo Displacement: Bored and stroked to 2,700cc Bore x Stroke: 87mm x 75.7mm Redline: Exceeds 13,000 rpm Boost: Exceeds 3.3 Kg/cm2 (Stage 1 was 2.2 Kg/cm2) Electronics: GReddy 80mm 3.5Kg/cm2 dual input boost gauge MoTeC M800 ECU and complete logging sensor array with EGT (x2), IAT (x2), Knock (x2), MAP (x2), wide band O2 (x2), launch, traction and air shifter control MoTeC Advanced Dash/Logger system MoTeC CDI/8 channel ignition spark amplifier MoTeC uprated high intensity ferrite coil packs (x6) MoTeC complete sensor array and logging of over 50 parameters (shock travel, G's, all fluid temps and pressures in engine, gearbox, diffs, etc) Bottom end: Custom 87mm AB-134 (Aluminium-Beryllium hyper-alloy) forged pistons (x6) Custom ceramic coated tungsten-carbide main crankshaft bearings (x6) Custom oil cooling system Custom titanium connecting rods (x6) GReddy lightened alloy pulley set GReddy 12 litre enlarged sump HKS /ATI twin ring fluid-based harmonic balancer JUN full stroker shaved counter balanced crankshaft JUN GT spec enlarged radiator JUN high capacity oil pump JUN oil sump baffle plates JUN strengthened connecting rod bolts JUN strengthened main crankshaft bolts Nismo N1 uprated water pump Top end: Custom camshafts Custom head channel modification and complete proprietary GT cooling system upgrade Custom oversized Inconnel exhaust valves (x12) Custom porting and polishing of cylinder head and runners with extensive flow bench profiling HKS exhaust manifold gaskets (x2) HKS metal head gasket HKS vernier cam wheels (x2) JUN brass valve guides (x24) JUN camshaft bearing set JUN GT surge tank (inlet plenum) with customised bell mouth entries and tuned runner design JUN intake gaskets (x3) JUN oversized intake valves (x12) JUN strengthened head studs (x14) JUN tappet shims (x24) JUN titanium valve retainers (x24) Mines triple baffled cam cover plate assemblies (x2) VeilSide 100mm throttle body assembly Turbo system: A'PEXi Drag Vmax/SPL Pro intercooler (718mm wide × 277mm high × 156mm thick) with two 80mm inlets and one 100mm outlet Custom dual 3.5" exhaust dumps, separate wastegate pipes into single 2.5" dump, exiting after front-left wheel Custom turbo piping of 80mm turbos (x2) to intercooler, 100mm from intercooler to 100mm throttle body Custom turbo system oil feeds, water cooling lines and modification of GT bearing cores to support higher shaft speeds GReddy Type-R Racing Blow Off Valve, with 3.0Kg/cm2 spring HKS 58mm external GT-Pro spec wastegates (x2) HKS 150mm to 100mm anodised aluminium bell mouth funnels (x2) VeilSide/GT exhaust manifolds (x2), split as 2 banks of 3 cylinders, each feeding one turbocharger and an external wastegate VeilSide/SPL GT-3540 turbo chargers (x2) with uprated customised GT-42 compressor wheels and compressor/exhaust housings Fuel system: Bosch Motorsport 850HP fuel pumps (x3) -80 braided fuel feed lines (x3) -60 braided fuel return line Custom 2,000cc injectors (x6) Custom 20 litre fuel cell, with competition spec re-breather system Custom oversized and multi tapped fuel rail MoTeC in-line high-flow fuel filters (x3) SX 6.0 bar high pressure fuel regulator Drive train: ATS carbon triple plate 9.0" clutch ATS front 1.5 way carbon LSD B&M air shifter modified for control via MoTeC ECU Cusco rear 2.0 way high-lock rate Drag/SPL LSD Custom solid engine mount system HKS/Berc uprated drive shafts, front (x2) and rear (x2) Holinger 6 speed sequential drag gearbox with uprated spline input shaft JUN modified hi-torque transfer case system Nismo N1 drive train mounts VeilSide hydraulic torque split control system Aerodynamics: Custom low drag rear wing assembly Do-Luck front aerodynamic under tray diffuser Do-Luck rear bumper bar and aerodynamic under tray diffuser JUN GT aero vented bonnet Trust drag front bumper bar with extensive modifications Suspension: Modified VeilSide Pro-drag coil over suspension system JUN Pro-drag/SPL coil over suspension system (for Pro-GTR class) Multiple strut bracing and body work strengthening VeilSide Pro-drag coil over suspension system (for street tyre class) Brakes: ATS carbon race rotors, front (x2) ATS carbon brake pads, front (x2) Endless CCM brake pads, rear (x2) Custom braided brake lines Simpson 200mph parachute Interior: Bride Zieg Carbon-Fibre/Kevlar race seats (x1) Chrome-moly 6 point (competition certified) roll cage Sabelt Indy 5 point 3" harnesses (x2) Weight reduction: Custom acrylic replacement windows Custom CFRP lightened boot Custom CFRP lightened doors Extreme stripping and weight loss program Wheel rims: BBS Le mans' LM limited edition, forged, (Gold) 18" x 10.5" for normal street tyres (x4) Rays Advan RG, forged, (White) 15" x 8" for Pro-GTR drag slick class (x4) Racing Hart CP-035R, forged, (Gold) 17" x 10" for street tyre drag class (x4) |
#57 (permalink) | |
would have used it for the track only. I dont know how much it when for , you have to go in with a XX bid or the vehicle inspectors will not bid on a faulty car.
"I am clever because I know the cause of my ignorance..." ~ Bruce Lee Last edited by paul cawson; 29th May 2005 at 12:30 AM. |
#58 (permalink) |
r33 gtst boy wats the point in copying and pasting neatly exactly mario's spec list
- JTL re-born again, used to have 571 posts 17th July 2003 Real D Dark and Evil drum and bass mix. Manchester's finest! http://www.witnessthesickness.com/Mi...z_Aug_2K61.mp3 PM me if you wanna hear more! My myspace http://www.myspace.com/thevacinty |
#59 (permalink) | |
Deffo enjoying the RB30 love, nice to see people have sence, make me the right offer and you can have mine ![]() |
