| View Poll Results: GTR Gearboxes.... | |||
| Stock box fine and serves its purpose well, no problems yet thanks.. |
149 | 43.19% |
| Stock box was fine but now causing some concern whilst changing.. |
80 | 23.19% |
| Stock box doing my head in now and needs changed asap! |
10 | 2.90% |
| Stock box let me down and now on 2nd.. 3rd... 4th...replacement.. |
21 | 6.09% |
| Rebuilt stock box and very happy now thanks! |
18 | 5.22% |
| Killed rebuilt box and need a really expensive one.. HKS..O/S.. |
9 | 2.61% |
| I have a really expensive box.. and am a smug b**tard thanks ;-)) |
37 | 10.72% |
| None of the above |
25 | 7.25% |
| Multiple Choice Poll. Voters: 345. You may not vote on this poll | |||
GTR Gearbox Poll
3rd to 4th grinds sometimes and is spoiling the Skyline experience for me...
putting up with it but will need to do something soon.... alas m o r e money to the liner fund... ahh well in a good cause I suppose. So... A small poll to see how the rest of you are getting on with your boxes.... ![]()
'Keep your friends close, your enemies closer..' |
Slight crunch going into Fifth gear on mine. Will fix but I am in no rush as I am doing a lot of hard pull aways. I could fix Fifth and blow One of the other gears
"I am clever because I know the cause of my ignorance..." ~ Bruce Lee |
#5 (permalink) | |
#6 (permalink) | |
#7 (permalink) | |
#8 (permalink) | |
![]() Only downside I've found (apart from the cost of the oil) is that in the winter it needs to warmup for a minute or so first thing otherwise its a bit tricky to get first gear and 9 times out of 10 you end up graunching from first to second when you first move off. It seems to be fine at this time of the year though. If it was for road use only then the Redline Medium Shockproof oil might be a better bet to avoid the problems I mentioned.
Cheers Stu R32 GTR - Godzirra Twin turbo RB25'd 200SX RS13 - 405bhp and 348lbs ft on 15psi |
Those thick oils are not a long term fix, I was going to try the Redline Rumble test day as a fix for my gearbox
kill or cure! ![]()
#12 (permalink) |
the best oil for the GTR gearbox is the "smurf blood" redline super light weight shock proof....
I had a heavy crunch 3rd to 4th.... when hot.... now? not a noise to be heard at any temp! so I would HIGHLY recommend the blue stuff! |
#13 (permalink) | |
#15 (permalink) | |
