LinkBack Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 12th October 2006, 10:08 AM   #211 (permalink)
Asim R32GTR's Avatar
Originally Posted by Hugh Keir View Post
sleepyfox,
As far as I understand it, the cam belt flex is induced by the resistance of rotating the cams + crankshaft flex.
As the engine becomes more loaded under high boost at high RPM the crank will flex more with each combustion which causes more inaccuracies in cam and ignition timing.
Removing the ignition timing aspect of the above by triggering the ECU from a non cam belt driven source is a large part of the solution.
How big of a problem is the fluctuating ignition timing??
To be hones, i knew about the drawbacks of using a cam driven sensor for crank position. But i never knew it was a problem until now.
Did i do the right thing in selling my pfc, and going for the autronic?
Asim,....
Old 13th October 2006, 10:46 AM   #212 (permalink)
R32 Combat's Avatar
I've turned the trigger disk now, modded the crank pulley and sorted out the 'fixing onto the bottom pulley' problem.
Next is milling the teeth...
SKYLAB TSC AVAILABLE THROUGH THE GTROC ONLINE SHOP.
My PS3 gametag is CLAGNUTS
Old 13th October 2006, 11:06 AM   #213 (permalink)
Any pic of your work so far Mr Combat
Asim...
Old 13th October 2006, 01:43 PM   #214 (permalink)
R32 Combat's Avatar
1st turn the pulley like this..
Then make this..
And it should look like this..
Obviously that are not bolted together yet and there are no teeth(30).
It's important that the outer part of the pulley has a little room to move without touching the trigger disk..
Old 13th October 2006, 01:53 PM   #215 (permalink)
ahapartridge's Avatar
Will you be getting the assembled unit balanced Andy?
ahapartridge is offline   Reply With Quote
Old 13th October 2006, 02:00 PM   #216 (permalink)
R32 Combat's Avatar
Good point, I hadn't thought of that. Then yes, I guess I will. Thanks
Old 17th October 2006, 11:40 PM   #217 (permalink)
Guys;
Not doubting that belt flex contributes to the scatter issue, but might it be exacerbated by wear in the CAS spline? There are cases where scatter has been alleviated significantly by addressing this.
Scooby is offline   Reply With Quote
Old 18th October 2006, 04:15 AM   #218 (permalink)
How is the milling process controlled? ie is it manual or are you cnc'ing it?
Would it not be easier to get the outer tooth profile wire cut and then perform the lathe operations?
You could use the key that is already used for mounting the shaft for the trigger wheel also. No need to bolt anything in. Also you then have the same reference and only that reference if you need to reassebmle the unit.
AndrewD is offline   Reply With Quote
Old 18th October 2006, 06:07 AM   #219 (permalink)
R32 Combat's Avatar
I'll CNC mill the teeth. I don't have access to a 4 axis EDM machine, which I would need to cut the teeth accurately. If I cut the teeth first, it would ring like hell turing the OD and I'l have a fair amount of chatter. I thought about mounting it straight onto the crank, but I don't think lining it up will be hard, I'd have to do that whatever I did.
Certainly I think the CAS mount on the camshaft IS an area where movement can occure, but thats not an issue doing it this way.
Old 19th October 2006, 04:47 PM   #220 (permalink)
R32 Combat's Avatar
I've finished the disk at last, its being plated tonight, I'll post up some pics tomorrow..
Old 20th October 2006, 01:00 PM   #221 (permalink)
R32 Combat's Avatar
The finished article.
Old 20th October 2006, 01:28 PM   #222 (permalink)
sleepyfox's Avatar
Nice work. Looks like someone had a similar idea to you with their RB26 powered 240z
Fox
My Skyline blog: http://fox-skyline.blogspot.com/
sleepyfox is offline   Reply With Quote
Old 20th October 2006, 01:39 PM   #223 (permalink)
NISFAN's Avatar
Good stuff Andy much neater than my bought laser cut job.
Do you not need a missing tooth for clocking engine position with the AEM? Or is it cam signal that positions cycle?
Sleepyfox,
Looks just like my setup for my DTA Fast, also on ATI damper.
Old 20th October 2006, 01:46 PM   #224 (permalink)
R32 Combat's Avatar
I don't need a missing tooth, I'll use the CAS #1 for sync.
I think missing tooth is pointless on a 4 stroke, what does it tell you? Where #1 TDC is, but which stroke? Hence using the CAS.
Old 20th October 2006, 01:53 PM   #225 (permalink)
NISFAN's Avatar
Yes true, but many aftermarket ECU's are designed to run without a Cam sensor, so as a basic requirement need a missing tooth.
This helps on ECU's like mine, because if the cam sensor fails whilst driving, it will go into wasted spark, and non sequential injection. Still allows me to drive home.
You'd be surprised at the number of people using non seq. on race type ECU's, even though they have the capability. Makes no difference to power apparently, so they go for simplest option.
