LinkBack Thread Tools Rating: Thread Rating: 8 votes, 5.00 average. Display Modes
Old 25th May 2006, 07:47 PM   #106 (permalink)
R32 Combat's Avatar
I fitted one of these today.
It's an old metro anti-run-on valve. Basically, its a solenoid that opens to let air in when the ignition is turned off.
We've wired it into the AEM to work as the idle speed control valve. We also fiddled around and wired the power steering pressure switch into the A/C control switch, so now, when steering pressure is applied, the revs rise a little. This soleniod isn't the perfect solution for the idle speed, but its fairly good. The AEM requires a stepper motor one ideally.
SKYLAB TSC AVAILABLE THROUGH THE GTROC ONLINE SHOP.
My PS3 gametag is CLAGNUTS
Old 25th May 2006, 08:24 PM   #107 (permalink)
With the detail given so far Andy,you need to open your own work shop for other Skyline owners.
Old 26th May 2006, 08:01 AM   #108 (permalink)
NISFAN's Avatar
Is the AEM not able to control the stock IACV?
Old 26th May 2006, 08:59 AM   #109 (permalink)
Pikey's Avatar
Andy you're a legend mate
Standard R32GTR / killed engine / killed another engine / 450bhp on N1s / killed N1s / 500bhp on single T04R / killed gearbox / sold. That's the short version anyway!
Drift-R
Old 26th May 2006, 10:20 AM   #110 (permalink)
R32 Combat's Avatar
Yes, the AEM does control the STD nissan AAC valve. However, I gave mine to Jim27 so I had to use something else. I've binned all the nissan idle speed gibbing. The Metro one is an easy fit, where as the nissan one has a stupid flange fitting on one end and it just takes up far too much room..
Old 27th May 2006, 06:29 AM   #111 (permalink)
Banned
Spot the difference.
does it clear the bonnet? or did you have to modify the bonnet?
GTRR is offline   Reply With Quote
Old 27th May 2006, 09:52 AM   #112 (permalink)
R32 Combat's Avatar
It didn't quite clear the bonnet, hence the brutal mod.
The turbo was about 3mm higher up than the bottom of the bonnet reinforcing bits.
Now it clears nicely.
Old 31st May 2006, 04:11 AM   #113 (permalink)
Jebu's Avatar
Send a message via MSN to Jebu
Awesome thread
By the way, there's a similar thread on SAU with the RB30 conversion albeit different from yours, just thought I'd link it here for information purposes
http://www.skylinesaustralia.com/for...howtopic=15420
564 bhp
472 ft/lb
Jebu is offline   Reply With Quote
Old 31st May 2006, 12:05 PM   #114 (permalink)
Pikey's Avatar
Is that induction piping not going to get sucked in on itself?
Drift-R
Old 31st May 2006, 12:26 PM   #115 (permalink)
Philip's Avatar
I would imagine that it's large enough not to be restrictive.
Phil
Philip is offline   Reply With Quote
Old 8th June 2006, 01:16 PM   #116 (permalink)
what power figure are you expecting from this? at what boost & what fuel
shanef is offline   Reply With Quote
Old 14th June 2006, 03:22 PM   #117 (permalink)
R32 Combat's Avatar
I don't know what power or torque figs to expect. I'll run 1.2 bar at first and see how it goes. I'd like to see 500hp and 500 ft/lbs of torque. That will be on 95ron cheap fuel.
It seems I've not put a bush in the end of the crank, which is the cause or my clutch issue. O'joy. A nice little job coming up real soon. I've ordered a Nismo clutch to replace the HKS item. It's to make the car drivable for a lady, namely my wife. Shes fairly insistant she should be able to drive it too.
Old 15th June 2006, 09:09 PM   #118 (permalink)
Madden's Avatar
good to see you back mate. hope your holiday was good and well done with the motor. top thread
Old 16th June 2006, 11:41 PM   #119 (permalink)
R32 Combat's Avatar
Cheers Jamie.
My clutch was held up in customs so it didn't arrive today. Gangsters...
Hopefully, the clutch will be fitted next weekend and the running in period will be over soon so we can start applying some boost and having a real play with the mapping.
I'e also bought a new exhaust, so the heighbours wont be so pi$$ed off everytime I fire it up. Bless them..
Next update soon, fingers crossed..
Old 17th June 2006, 02:06 PM   #120 (permalink)
Please don't be driving it without the spiggot bush.
The lack of has a nasty habit of very quickly stuffing the input shaft bearing.
A mate did the same with his rb30det conversion, his box now constantly vibrates and makes huge noises, all though it has hung in there for quite some time.
Awesome build up, very keen to see the reasults.
272 or 280duration cams work very nice with the RB30's.
Cubes is offline   Reply With Quote
