#18 (permalink) |
No need for a translation, it's very easy if you mean upgrading from factory to MFD II.
You get 2 boards and you just change those out for the current 2 boards....... pretty straight forward. Then once reassembled, just follow this to setup. MFD setup and calibration info
Cheers Fraser |
#19 (permalink) |
I have a 1999 non-Vspec R34 GTR as well (with the standard basic MFD) - does anyone know if (for e.g.) the MFD here: Nismo - Multi Fuction Display - Version II - Nengun Performance comes with all the sensors for the EGT and inlet temps as part of the package? Or do you have to buy them separately?
Thanks,
Nissan Skyline R34 GTR |
#20 (permalink) |
Didn't say anything about it in the text, but I will recomend that you check out www.takakaira.com
Nismo - Multi Fuction Display - Version II - Nengun Performance You might even save cash on going there... That's were I got mine... |
#22 (permalink) |
There are 2 Nismo MFD upgrade packages; one for the V-Spec model (without egt sensor), and one for the non V-Spec model (w/EGT sensor).
Obviously you need the latter. Just make sure when you order to confirm.
Pearl Black R34 GT-R V-Spec As featured in April '07 Japanese Performance Top Gear - JC - "I thought when i drove the Mitsubishi Evo X the other day, that there was no way the GT-R could be worth twice as much money, I mean I just thought no way it could be twice as good, but it is!" |
#23 (permalink) |
Thanks mate, appreciate it.
