#106 (permalink) | |
GTROC NUR POWERED MEMBER
fortunately i have no plans to sell mine, ever![]()
#108 (permalink) |
This is the most stunning Gtr i have ever seen and probably ever will.
I can only hope that i someday will be able to get my 34 up to this spec but i don't think that will ever happen. In my world this car is worth the asking price, a beauty with a spec to kill for. Terje.
Bnr34. Progress in all directions. |
#109 (permalink) |
Administrator
I have to agree with ol' Howsie here.
I respect what many do to their cars in the name of individuality and, perhaps, the pursuit of your own goals. I do kinda wish those goals would have been met on a standard 34 (token smilie)The Nur for me was the culmination that was derived from an almost obsessive state of mind - I only wanted the best without compromising what I felt the Nur stood for - the last of the line, hand picked after months of long searching, hand picked parts from the Nismo shop, fitted by Nismo experts. The car really was special as not only was it unique in itself, but it was further injected with the kind of crazy messed up enthusiasm only Nissan's technical engineers can muster. Here are Nismo engineers giving the car a once over on the Nurburgring: I don't want nobody to take offence at what is, essentially, my own opinion. Had the car been in the exact state of tune/condition as I'd sold it, then yes, unequivocally, the car would be worth that. Right now? I guess it's worth whatever anybody's willing to pay for it. It's also often compared to the Z-Tune. We need to remember this car was actually based on the Z-Tune when I built it as the Z-Tune was not yet available for public sale. In fact, I offered to buy the actual Nissan JP S-Tune car but was refused as they did not want their car to leave the country. The Z-Tune at the time was a highly secret and guarded affair, they did not want anybody knowing any details about the internals. I sometimes wish I was affluent enough to have kept this car forever. I was extremely saddened to have sold this car 3-4 years ago. |
#110 (permalink) | |
I totally understand both of your viewpoints and I'm sure its shared by many others. Myself, I don't understand what all the fuss is about, because all the special parts referenced in your post are still on it. In addition there were a lot more Nismo bits added to it, from the enlarged Nismo input shaft on the gearbox to handle more power, to the Nismo Intake Plenum/Collector (a very expensive piece of kit), the titanium strut brace - all straight out of the Z-Tune catalogue. Anything removed from it, ie the S-Tune suspension was replaced with the more up to date equivalent, the S-Tune HA's. The G-Max clutch plates were replaced with the uprated enlarged input shaft Nismo plates etc etc. With regards to the "kind of crazy messed up enthusiasm only Nissan's technical engineers can muster", whilst I agree the package was great, the only part that I felt let the car down, is ironically the only part of the car that even you deviated from Nissan/Nismo, and that was the engine. When I bought the car it had HKS cams, Tomei pulleys, HKS metal gasket, EVC, Apexi ECU etc. There was no doubt good reason for this, which was that Nismo hadn't really released any engine packages or parts at that time. While it was a cracking engine, I was used to the torque from my Supra and in this department the Skyline felt lacking. In essence, all that has really changed in the engine bay, is better cooling (Trust sump,trust oil pump,trust front diff cooler, trust remote oil filter, ARC Radiator, Arc air remover kit) gone are the N1 Turbines and the N1 pistons, replaced with HKS pistons, rods and crank instead. The Top Secret Engine is still based on an N1 block, has an N1 water pump, and the HKS 2.8L kit is probably one of the most reliable and well tested Stroker conversions out there and is very similar in spec and dimensions to the subsequent Tomei based RB28 which Nismo later offered. This brings the Nur even closer to the Z-Tune - loyal to the concept you were chasing. The cams are still HKS just as you had. The engine is fully balanced just as it was. The Cam covers are still gold ![]() So with the exceptions of higher strength Pistons, rods and crank, and a Trust oil pump instead of an N1 one, the engine is very similar (although the head is now ported and polished). The only real area of deviation is the Single Turbo conversion. It wouldn't be much work to change them to twins. Personally I'm a fan of big singles, but bolt on a pair of RB28 Z-Tune twins and your right back to your Nismo roots. Whilst I agree with everything in your post, everything that was, still is. If you had driven the car I don't think you can but be impressed and if there were no pictures up of the engine bay, nobody would even know what is contained within! I know you didn't agree to me modifying the car further, if you were a dead man you'd be turning in your grave, however, everything you did that was factory/Nismo, I left well alone. The Nur engine was already 'compromised' and I felt what I did was further improvement in every department (longevity, driveability, performance and reliability; through Increased Cooling and Delivery, improved efficiency, Strengthened Components and Full Engine Control and monitoring -Active knock control and Permanent wideband Lambda). By comparison the N1 engine was at the limit of what the pistons could reliably take, oil needed to be overfilled on track to protect from severe oil surge (probably why Tims Nur engine let go in the first place), the Apexi used to allow knock in warm weather and didn't have any active knock control, the AFM's were crude (drainpipe with Air flow sensors sealed in) the sealing of the ports from the intake plenum was careless with red sealant obstructing the ports (I've got a good pic of this) and so on. What I did, was very sensibly specced, probably why I'm a little protective of any sentiments implying that I've diminished the car, in fact one of the most poignant comments in this thread for me was from Hugh Keir "That is one of the most intelligently specced Skylines in the UK". Coming from one of the most technically intelligent people on this Forum, that was indeed a compliment ![]() Please note that no offence taken, we're just discussing like adults. I'm of the opinion that unless there is anything constructive to ad to a for sale thread, anything negative that is posted is disrespectful to the seller. Now that this thread is no longer linked to the Pistonheads advert it's essentially no longer a for sale thread, so please feel free to post your views. Cheers Nito
"She'll make .5 past lightspeed" |
#113 (permalink) | |
PMSL!!!..... ![]()
Too often we lose sight of life's simple pleasures. remember, when someone annoys you it takes 42 muscles in your face to frown. but it only takes 4 muscles to extend your arm and bitch-slap the motherfuNker upside the head. ----------------------------------------------------------------------- Blown by a T04z - built and mapped by Tweenierob ..... http://www.perfect-touch.co.uk http://www.junsuperlemon.co.uk http://www.neweraimports.com |
