Kwik fit do a check,clean and re-gas for £44.95
I have just been down there and they tested for leaks twice and both times it came up with a leak.They did say the machine had been playing up and called for an engineer to come and service it.So when the machine is serviced I will be going back to try again.
You only pay if they re-gas so if you do have a leak it wont cost but you then have to go and find the leak elsewhere.
Some of you may not be to keen on kwik fit but they do pretty much what an aircon specialist does but for half the cost..
