Old 13th May 2008, 04:58 PM   #5 (permalink)
Cornhoolio
In The Night Garden
Cornhoolio's Avatar
Have you investigated the possiblity of one of the BOV's leaking?
Split hose that only opens up on boost?
I would imagine a "stuck" or seized turbo would effect the running of the engine at all conditions not just when coming on boost. It would be like restricting the exhaust massively on the rear 3 cyls at all RPM'S, not good
If the car runs fine off boost at all revs, to me, this would point to an air (boost) leak. Black smoke = unburnt fuel.
Remove the AFM's and blank off holes, pressurise inlet system with compressed air to 15psi and use Snoop or Fairy Liquid/water mix in a sprayer and spray it all over the inlet and turbo pipework, check for leaks that way.
Just my thoughts
Are the turbo's ceramics?
Hope this helps
Ian
コーンホーリオ
Cornhoolio is offline   Reply With Quote
