Default geometry set to circuit
I spoke with Nissan about the handling problems and they said it might be due to the default factory settings being circuit mode. still, i think this is not enough to cause the issues i had at the weekend so i'm going to ignore them and go with a mine's solution which i know a) can be adapted for the road properly and b) is 2 secs a lap quicker at tsukuba.
For everyone else out there with a gt-r at least you now know there is another geo setting that can be used. If you never intend to use it on the circuit then i suggest changing the geo. Unfortunately only the HPC has the settings and i have no idea what they are.
