Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > Technical > Turbos
Old 23rd March 2008, 08:12 PM   #1 (permalink)
Shakkagts-t
Shakkagts-t's Avatar
Disturbing Noise from turbos
Had the GTR out for a nice long run last weekend and have noticed a rather disconcerting noise when it comes on to boost.
I'd noticed it last week when i took her out the drive but assumed it was because it wasn't fully heated up.
The noise used to go away after a few miles but if i stopped for 10 minutes or so, even if i left the car running, the noise would come back,??????????!
Now its there all the time, louder when i first hit the boost and getting quieter when its on full chat!
Ok going to try and describe the noise! It goes R r r r r r r r like if you roll your "Rs"
Just getting abit of the Skyline paranoia too, scared sh!tl3ss incase a turbo goes poop and wreaks the engine! Wouldn't say it was down on power or really smokey either!
Please help, only got her registered 3 weeks ago!
Shakkagts-t is offline   Reply With Quote
Old 24th March 2008, 12:07 AM   #2 (permalink)
ecoshardcore
ecoshardcore's Avatar
are you down on power? What does your boost gauge read under full throttle?
For all your turbocharged desires!
Aem,Defi,Garrett,Hallman,Tial,
Psi Supply
sales@psi-supply.com
www.psi-supply.com
Garrett GT2860-10 turbos instock
-5's will be here soon!
ecoshardcore is offline   Reply With Quote
Old 24th March 2008, 12:18 AM   #3 (permalink)
harris2182
harris2182's Avatar
sounds like the bearings gone and the turbin is rubbing on the inner casing when your hitting boost.
sounds identical to wat happened to my vw 20v turbo when that failed
harris2182 is offline   Reply With Quote
Old 24th March 2008, 07:12 PM   #4 (permalink)
Shakkagts-t
Ohh poop!
Is there anyway of knowing which ones fecked without pulling them out?
Are both the front and rear turbos the same?
Will there be play in the shaft if its knackered?
Sorry for the lack of knowledge when it comes to the GTR but not had it that long.
Does not feel down on power at all, as for the boost gauge it has a row of aftermarket gauges fitted but no boost gauge
Old 24th March 2008, 07:54 PM   #5 (permalink)
harris2182
harris2182's Avatar
i could be very wrong though mate. best put a boost gauge on there to get aa better insite to the problem
Old 1st April 2008, 04:59 PM   #6 (permalink)
jock
Send a message via MSN to jock
i had a very disturbing noise last weekend from what i thought was a turbo.
it only happened when the car made boost, went away when the car dropped off boost and had me thinking the worst,
The car was still making the same boost pressure just as quickly as it had done before the noise so i didnt wanna beleive that a turbo had gone faulty but it definatly sounded like it.
on inspection i noticed that my ac belt was loose and my alternator belt wasnt the tightest, tightened them both and problem solved,
1 huge sigh of releif later and i was loving my GTR again
bring on some mapping
jock is offline   Reply With Quote
Old 1st April 2008, 05:27 PM   #7 (permalink)
Shakkagts-t
Ment to update this thread but just been busy loving the GTR again! Noise has dissapered!! Had her out most of Saturday and again Yesterday and no nasty noises at all! Puting it down to lack of use, think the cars lucky to have done 200km since it was imported in September! Big smiles all round! Need to think what to spend the money i'd put by for replacing the turbos on now!
Old 11th May 2008, 06:42 PM   #8 (permalink)
Shakkagts-t
Ok, noise back with a vengance!
Really odd one this, seems to come on with boost but on the odd occasion have heard it just after starting up and pulling away around 1500rpm. but tends to go away pretty quickly and only comes back when on boost!
Stripped the pipework off around turbos and intercooler and there seemed to be quite a bit of oil in them, but not much play in the shafts of the turbos about 1-1.5mm some oil in turbos too.
Also checked the breather pipe between cam covers and no oil at all!
Dont want to pull the turbos off and replace incase its not them thats knackered!
Please help!
Sean
Old 12th May 2008, 07:15 AM   #9 (permalink)
kingsley
kingsley's Avatar
Do you have a boost controller fitted? If so, does it do it if you turn the controller off?
Cheers,
Kingsley.
Old 12th May 2008, 10:07 AM   #10 (permalink)
Shakkagts-t
dont have a controller fitted m8, driving me mental! Took the day off work to get something done with it, now not sure if i should build it back up or start pulling the turbos off
Old 12th May 2008, 05:13 PM   #11 (permalink)
purpleskyline
purpleskyline's Avatar
Seeing as your half way to getting them off i would and get them inspected,
better being safe than if a bearing collaspe and blade breakin and entering engine, causing more damage.
what colour is the smoke out of the exhaust on startup, then warm let tickover for 20 mins tap throttle check colour again, could be an oil seal
purpleskyline is offline   Reply With Quote
Old 12th May 2008, 06:08 PM   #12 (permalink)
kingsley
kingsley's Avatar
I was just wondering whether you just had a noisy boost control solenoid - I can hear mine when driving along on part boost. I don't know what the stock one sounds like though - or whether there even is one as stock?
The noise mine makes could be decribed as "R r r r r r r r" in the way you say.
Cheers,
Kingsley.
Old 12th May 2008, 07:06 PM   #13 (permalink)
langerdan
langerdan's Avatar
hi i had a turbo problem with my gtr 2 yrs ago at cruising speed in fifth if i floored it between 2000 revs and 4000 revs the car would jerk a small bit and i could hear a dull groaning noise from the passanger side of the engine,i guess you could describe it as a rrrrrrrr noise
also the boost gauge would rise and drop a tiny amount in syncro with the jerking
i spent months trying to solve this problem
the turbos appeared perfect no shaft play or bearing noise
eventually i got so sick of pricking around with it that i ripped out the turbos and got them steeled in turbo technics
even the guy that built the turbos in turbo technics said he couldnt find any issue with the turbos
however when i fitted the rebuilt steel turbos the problem was eliminated
i reckon all it takes is for one turbo to become a small bit weaker than the other to cause problems
thats my opinion
langerdan is offline   Reply With Quote
vB code is On
Powered by vBulletin Version 3.6.1
Search Engine Optimization by vBSEO 3.0.0 RC4
© 2001-2007 Cem Kocu
