#31 (permalink) |
as yours also make no sense to me .. you say that the only issue was running the oem damper ..so that impiles that you had bottom end problems ?
I have gone on my own experience and have sort infomation on the subject ..i believe that the issues where resovled in 1999 in Australia and have only changed a liitle from then track cars have been running the above set up and i would sufggest that you read the link to skylines australia sydneykids thread is one the best i have read on this forum... each to there own but saying that you ran yours with the problems that you found on rebuild ....could they have been different with more info. as for preaching no its tried and tested.. you have your approach yes but don't go around say that anothers is bull just because you may not have tryed it. Your last comment about cavitation and running the sump dry like i said its all related to keeping the engine a live under changing conditions. where is tynado he will explain this. Look up google I'm done Last edited by gibson; 20th April 2008 at 12:29 PM. |
#37 (permalink) |
I believe my Tomei oilpump has come to my local postal office, going to get it in a few hours
My singleturbo machine: http://www.gtr.co.uk/forum/upload/96...r-swedish.html |
#38 (permalink) |
Tadaaaaaaaaaa:
#39 (permalink) |
Hi, i have now broken the N1 pump on my time attack R32. I quess it didnt like the high revs. Its not completly broken , just the gears that have broken in some pieces. this broke the sealing, and made an big oil leak. still had oil pressure when this happened. but after reading this tread, i think i just will change the gears to Reimax gears, But who sells them, other than greenline??
cheers |
#41 (permalink) | |
anyone?? really need to order this kit from sombody soon |
#42 (permalink) |
Searched for 30 seconds on google and found this:
Reimax Oil Pump Gear Kit Skyline GT-R RB26DETT
#43 (permalink) | |
