Go Back   GT-R Register - Official Nissan Skyline and GTR Owners Club forum > General > Nissan Skylines including R32, R33, R34 and others > General Stagea Chat
Old 18th May 2008, 09:12 PM   #1 (permalink)
paul palmer's Avatar
Stagea key fob!
Do any of you Stagea guys know if its possible to get another key and fob as a replacement? i only have 1 key/fob and concerned if i lost it im buggered!!. I can get another key/fob from japan but obviously wont have the same code. any help would be appreciated.
Paul.
paul palmer is offline   Reply With Quote
Old 19th May 2008, 06:00 AM   #2 (permalink)
RSVFOUR's Avatar
Ive not checked but I would bet that a stagea key is the same blank as a R33 ( everything else is) so try a nissan garage or a specialist key cutting place and ask them to copy your Nissan r33 key
a further thought - if you order one from japan and have all the orignal docs (japanese) and numbers they may be able to order one that will fit your locks .
RSV Four FFC
(Flying Fridge Carrier...... now with twin turbos)
Old 19th May 2008, 07:38 AM   #3 (permalink)
stagea key
thanks for that, my fob has 2 buttons for lock and unlock, does the R33 have the same then for the factory fitted alarm that the fob works for?
Paul.
Old 19th May 2008, 07:42 AM   #4 (permalink)
Andy W's Avatar
the key for mine is the same as the R34 key
bovered me, do i look bovered, bovered , no
AA join here
Andy W is offline   Reply With Quote
Old 19th May 2008, 05:24 PM   #5 (permalink)
Caoboth's Avatar
Send a message via ICQ to Caoboth Send a message via MSN to Caoboth
hmm my key has two buttons on it also however looks like someone has stuck a pen into them both, does the stagea have central locking on it ??
And if so i'd be after a key also
Andy
Caoboth is offline   Reply With Quote
Old 19th May 2008, 11:15 PM   #6 (permalink)
RSVFOUR's Avatar
Andy
All Stageas have central locking but not all have keyless entry . However if you have a key with two buttons then you have got it.
if its not working might just be the batteries worth a try .
RSV Four FFC
Old 20th May 2008, 08:37 AM   #7 (permalink)
Caoboth's Avatar
Well i gave it a shot opened it up, seems last owner never changed the battery so its leaked onto the circuit board
Doh!
Andy
Old 20th May 2008, 01:12 PM   #8 (permalink)
RSVFOUR's Avatar
Well at least you know the problem and that you do have remote locking.
Might it be possible to clean it up ?
RSV Four FFC
Old 21st May 2008, 07:41 AM   #9 (permalink)
Andy W's Avatar
key should be available from Nissan, fairly sure programing it wouldn't be too dificult to get done either
AA join here
Old 21st June 2008, 07:24 AM   #10 (permalink)
Stagea Key Fob
My Stagea key fob has the same problem, the previous owner used a pen to press pad harder rather than replacing the battery. Also , only have one key.
I went to my local Nissan dealer who found the Stagea key fob on a cd. The result.. £10 ish for a blank key without the remote entry buttons, £200 plus for a blank remote entry version!!!
Grimm1 is offline   Reply With Quote
Old 23rd June 2008, 01:11 AM   #11 (permalink)
if yuo dont know if you have the keyless entry, take down the trim under your steering column
you will see the nissan factory alarm/keyless entry box and wires. if you dont have it, you dont have the option
yokotas13 is offline   Reply With Quote
