Old 12th June 2008, 03:43 AM   #1 (permalink)
A/F Controller HELP !!!!
i am in the market for a A/F controller
which one is good
besides the listed ones what else do you suggest ?
any0ne help me pleasE !
so far these are the compant that makes AF guages-help me pick one from the bunch
-AEM ugeo
-Innovate XD16
-PLZ DM5
felixy69 is offline   Reply With Quote
Old 12th June 2008, 11:50 AM   #2 (permalink)
Innovate or PLX mate
Old 12th June 2008, 12:28 PM   #3 (permalink)
Stachi's Avatar
Innovate... also hooks up with Datalogit..
Marc
Old 12th June 2008, 03:38 PM   #4 (permalink)
I have an innovate kit , i'm not impressed it reckons my AFR's are a lot richer than i think they are eg 9/1 on full boost and 12/1 on light throttle i just dont belive the car would run as well if that were true.
Have a look at the innovate technical forum as well , loads and loads of unhappy customers
I'm thinking about fitting the VEMS afr/egt kit instead
Horsham Developments
Richf is offline   Reply With Quote
Old 12th June 2008, 03:40 PM   #5 (permalink)
SamuraiSam's Avatar
My personal opinion is that the Innovate LC-1/LM-1 are superior to any other consumer-grade (~$300 price point) wideband o2 controller on the market. I'm not talking about a fancy NTK or Horiba meter, but compared to the AEM, PLX, Zeitronix, etc.
UEGO means Universal Exhaust Gas Oxygen sensor.
There is nothing more difficult about the LC-1 than any other wideband. I will never purchase a consumer-grade wideband other than an Innovate product.
Good, solid, factual information. I have an LM-1 and it works great. If Bosch supports Innovate's methodology, I am not one to argue.
Wideband o2 questions - FreshAlloy.com Forums since I can't edit the post to copy across the quoted links. There is a lot of good information on that link. There are a lot of people who are smarter than me that also recommend only the Innovate units.
Old 12th June 2008, 03:51 PM   #6 (permalink)
SamuraiSam's Avatar
99% of the people on the Innovate forum that have issues like you simply do not have their gauge setup correcty. Attach a laptop computer, open logworks, and look at your AFR. If it matches what your gauge says than, that is your AFR. If it doesn't then you need to configure your outputs to match what your gauge is expecting. The 0-5v curve is easy, easy, easy to set up.
Old 12th June 2008, 04:13 PM   #7 (permalink)
I have a PLX R-500 which is a good bit of kit, but for a basic Lambda controller and gauge for permanent install I'd go for Innovate LC-1.
Old 18th June 2008, 02:13 PM   #8 (permalink)
NISFAN's Avatar
Found this on the Zeitronix site.
AFR meter shootout
I use a Zeitronix Zt-2, and am very happy with it. Matched MOT machine very closely.
Old 18th June 2008, 06:39 PM   #9 (permalink)
SamuraiSam's Avatar
I noticed that that AFR meter shootout does not include their test results just comments, and being an Import Tuner article has plenty of inaccuracies and blatantly incorrect statements (a few just in the first paragraph!)
Here's a better more technical review.
Wideband O2 Sensor Shootout! | FordMuscle Magazine
Innovate was granted permission to reprint the article in full (you have to be a paid subscriber to see the entire article on Ford Muscle.com
http://www.innovatemotorsports.com/r...B_Shootout.pdf
Would highly recommend reading it for you Zeitronix/AEM/PLX fans out there.
Old 21st June 2008, 07:07 PM   #10 (permalink)
SamuraiSam's Avatar
Link to an independent third party repost of the Ford Muscle wideband o2 shootout:
Wideband O2 Sensor Shootout TEST! - EMSPowered Forum
Old 29th June 2008, 05:43 PM   #11 (permalink)
Tried what you said and connected the lc-1 to my laptop and logworks matched the data from the gauge
I still dont believe what logworks and the gauge is telling me 11.5 on tickover and drops into the low 9 range on boost , it should be fouling the plugs and covering the road with black smoke at that ratio but it isnt , the car is running really well but is certainly a little rich
Old 29th June 2008, 06:08 PM   #12 (permalink)
SamuraiSam's Avatar
Have you removed the sensor from the exhaust stream, and done a free-air calibration? This needs to be done periodically. easy to do, there are instructions with your controller.
If that doesn't change anything, replace the sensor. It's a $60USDpart and you can get it at any Volkswagen or Audi dealer (or from an Innovate dealer). If you still don't believe the numbers head to a dyno and hook up to a tailpipe sniffer and your wideband at the same time to verify.
Old 29th June 2008, 07:03 PM   #13 (permalink)
done plenty of free air calibrations but my next step will be to confirm the data with another wideband fitted to the car .
shouldnt have to replace the sensor already the car has only done about 400miles since i fitted the innovate kit
Old 29th June 2008, 10:41 PM   #14 (permalink)
Madden's Avatar
I just brought the LM-1 Innovate afr reader. Got it from the states for £165 delivered.
Old 30th June 2008, 12:42 AM   #15 (permalink)
SamuraiSam's Avatar
I guess my question is are you doing the calibration correctly? If you do it incorrectly then you can run into the exact problem you have - way incorrect readings.
