Dyno 683whp - Pump Gas - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Go Back   GT-R Register - Nissan Skyline and GT-R Drivers Club forum > General > General Nissan Skyline Chat
Old 6th March 2009, 04:29 AM   #1 (permalink)
gestun66 is unaware they can edit their status
gestun66's Avatar
Cars owned: 1991 R32 Skyline GT-R
O.K., I finally got off of my butt and had the GT-R tuned. 683whp at 22psi (1.5bar) on pump 93 octane gas. Engine hp with 15% powertrain lose is 785hp. I feel that's plenty for pump gas, so I'll leave it there. Next, I will go for my hp goal of 800whp on Q16 race fuel. Still have to upgrade ignition system from stock. 800whp should be no problem?
Dyno sheets and video at link below.
Pictures by gestun66 - Photobucket
Gary Stewart
1991 Skyline GT-R (BNR32)
2006 350Z
2003 Sentra SE-R Spec V
gestun66 is offline   Reply With Quote
Old 6th March 2009, 06:09 AM   #2 (permalink)
plumwerks is enjoying the contrast
Cars owned: Nissan Skyline, Mazda 6 & Z32
Great results,bring on the 800.
plumwerks is offline   Reply With Quote
Old 6th March 2009, 07:20 AM   #3 (permalink)
Adam Kindness is phu phu phu
Adam Kindness's Avatar
whats the spec?
- Sponsored by Ultralite &
'81 Porsche 911 SC 3.0
'08 Navara Outlaw
Old 6th March 2009, 07:28 AM   #4 (permalink)
R35 Section manager
TREG's Avatar
Cars owned: RS6, R35 GTR, R33 GTR
Massive results.
What spec do you have?
Contact me if you need a Wedding Photographer.
Old 6th March 2009, 01:06 PM   #5 (permalink)
gestun66's Avatar
Originally Posted by Adam Kindness View Post
whats the spec?
Gary’s 1991 R32 Skyline GT-R:
Bottom End:
Stock Block (Bored/honed to 87.0mm)
R33 Stock Crank (Balanced/polished and checked for straightness)
Carillo Rods H-Beam, WMC Bolts
CP Pistons, 87.0mm, 9.0:1 Custom CR
ACL H-Series Rod Bearing Set, 19mm Wide, Nissan SR20DET, +.001
ACL H-Series Main Bearing Set
ARP Main Stud Kit
ATI Super Damper (Street)
Head:
Supertech Iconel Exhaust Valve, +1mm
Supertech Intake Valve, +1mm
Supertech Dual Valve Spring, 92in/82ex lbs on the seat
Supertech Titanium Retainer
Supertech Intake Valve Stem Seal, SR20DET
Supertech Exhaust Valve Stem Seal, SR20DET
ARP Head Stud Kit
Tomei Procam 270 cams 10.25mm lift (intake and exhaust)
Power Enterprise Grommet "Heavy Metal Head Gasket" T-1.1mm
Power Enterprise Super KEVLAR II timing belt
A’PEXi adjustable cam pulleys
Tomei metal intake and exhaust gaskets
Engine Lubrication:
Tomei Oversize Oil Pump
GReddy Deep Sump Kit
HKS Twin Oil Coolers with Filter Relocator and Thermostat Bypass
Calico Coated Pistons, Main Bearings, and Rod Bearings
Fuel:
RC Engineering 1000cc fuel injectors (matched set)
Two in-tank MKIV Supra Turbo fuel pumps with custom aluminum sump
GReddy fuel rail, two -6 AN inlets, one -6 AN return
Aeromotive adjustable FPR
Retrofit HICAS hard lines with dual -6 AN fuel fitting for duel fuel feed
Aeromotive -10 AN fuel filter
Fuel Cell Foam
Engine Cooling:
Koyo 3-core all aluminum radiator (Modified with Moroso billet aluminum filler neck and 19-21lbs cap)
Nismo N1 Water Pump
Twin 12” electric fans with thermostat control
Intake:
GReddy Intake Manifold
HKS 80mm hard piping kit – (modified to 100mm to accommodate GReddy intake manifold)
GReddy 3-core Intercooler
A’PEXi Racing Blow-off Valve
RaceMax Throttle Body Shaft Seals
Turbo and Exhaust:
Twin GReddy TD06L2-20G 8cm
A’PEXi Racing Wastegate
Custom 2 to1 downpipe to 95mm piping
Saurus stainless steel exhaust manifold
Twin Blitz power filters
JIC Magic Stainless Steel one-off 90mm (3.5”) Racing Exhaust
HPC HiPerCoat® Extreme coatings on turbine exhaust housings, exhaust manifold, wastegate housing, and downpipe
Drivetrain:
OS Giken "Crossmission" gear set
OS Giken triple plate clutch / flywheel
Nismo motor and transmission mounts
Top Speed Hicas eliminator kit
Suspension and Chassis:
JIC Magic FLT-TA2 racing coilover system - 12kg/9kg Front//Rear
Cusco Front Strut Brace
Cusco Adjustable Front Tension Rods
Electronics:
Power FC D-Jetro tuned by Mazworx
Extreme Torque Split Controller
Greddy Profec B Boost Controller (Blue)
Greddy Turbo Timer (Blue)
Shoes:
18x9.5 Rare Hasemi Racing 18" Alloys (2 piece)
Tires 265/35-18 all around
Exterior:
Do-Luck Full T-2 Body Kit
Do-Luck T-1 Rear Wing
Nissan Racing Purple Paint
Interior:
Cross racing seats
Autometer Pro-Comp Tach
Greddy Boost and Exhaust Temp Gauge
Alpine Stereo with Infiniti speakers
Power Goals:
750-800 ATW [email protected] 2.0~2.3kg boost
Gary Stewart
2006 350Z
Old 6th March 2009, 01:24 PM   #6 (permalink)
Bolle is randomcreations.se
Bolle's Avatar
Cars owned: R33 GT-R with 1119HP (931WHP)
Nice work
Bolle is offline   Reply With Quote
Old 7th March 2009, 04:23 PM   #7 (permalink)
gestun66's Avatar
Originally Posted by Bolle View Post
Nice work
Thanks!
Gary Stewart
2006 350Z
Old 7th March 2009, 07:54 PM   #8 (permalink)
chas is using the pedal on the right
chas's Avatar
Thumbs up Wow
Superb spec, and that T-2 kit is the best there is IMHO.
Charlie.
chas is offline   Reply With Quote
Old 15th June 2009, 02:03 AM   #9 (permalink)
95GTR600 is looking for 9.7 Full Trim
95GTR600's Avatar
great results..... did you go with better fuel yet ?
95GTR600 is offline   Reply With Quote
Old 15th June 2009, 12:52 PM   #10 (permalink)
Madden is unaware they can edit their status
Madden's Avatar
Cars owned: R32 gtr 1991
Thats awesome mate. Well done and hope you enjoy it.
1ST PRO/STREET DRAG SERIES ROUND ONE (12.3-13.3)
1ST PRO/STREET DRAG SERIES ROUND TWO (11.3-12.3)
NEW PB 11.14 @132MPH
