A Basic Guide to Tyre Pressures - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Go Back   GT-R Register - Nissan Skyline and GT-R Drivers Club forum > General > Nissan Skyline > Brakes, Wheels, Tyres and Suspension (Skyline)
Old 16th April 2009, 03:59 PM   #1 (permalink)
jae
jae is an independent author
jae's Avatar
Cars owned: Terrano II 2.4i SE
I've been looking for the correct pressure to run my new tyres at, and found rather a lot of not much. So I went hunting, and didn't find a lot more, until I stumbled across this, which is what I am using. Thought you folks might like to use it as well.
The baseline method from Oscar Pereda of BF Goodrich. He suggests this as a good starting point if you have abolutely no guide as to what pressure to use in your tyres. This starting point should be regarded for road use only.
(Vehicle Weight in pounds imperial/100) + 2 psi at heavier end + 2 psi all around if suspension and alignment are stock.
Example:
Stock 911, 3,000 lb.
(3000/100) = 30 psi
Add 2 psi all around = 32 psi
Add 2 psi to heavy end = 34 psi at rear
With modified suspension, the result would be 30 psi front, 32 psi rear.
SO:
Stock R33 GTR = 1530kg = 3366lb.
3366/100 = 33.66
Non standard suspension, so only adding 2psi to heavy end.
36 psi front, 34 psi rear.
But I'm a fat bastad, so that adds 240lb (let's be creative with the scales, eh?).
Adding 2.4 and rounding down for the tyre's stated maximum pressure (40 psi) gives 36 at the rear and 38 at the front.
PSI to Bar is 14.5038:1
Pounds (lb) to kg is 2.2:1
NOTE: Compensation for driver weight is my own addition, not mentioned in Oscar's baseline calc.
In all fairness, I should point out that my R33 GTR on 265/35/18 was running 34 front and 32 rear and that was superb. But me new tyres are bigger with a lower profile, so this is why I went looking.
I remember fashion - didn't like it last time either.
My publishing:
My writing:
jae is offline   Reply With Quote
Old 16th April 2009, 04:08 PM   #2 (permalink)
moleman is veteren Bongard Club
Real men use a H-Pattern.
moleman's Avatar
Adding to FAQ a sticking it.
Nice one Jae.
Registration
is now on a vehicle, but I am always open to offers.
Old 16th April 2009, 04:32 PM   #3 (permalink)
Site Admin.
Mookistar's Avatar
38psi on a 33?!?!
are you shitting me?
mook
Autoguide.com
Old 16th April 2009, 04:36 PM   #4 (permalink)
Multics is meh
Multics's Avatar
Cars owned: R33 GTS-T
Originally Posted by Mookistar View Post
38psi on a 33?!?!
mook
I would say that's a bit much as well and that it would make quite an uncomfy ride on low profile tyres. Interesting read nevertheless.
(OO\ SKYLINE /OO)
Multics is offline   Reply With Quote
Old 16th April 2009, 04:37 PM   #5 (permalink)
Site Admin.
Mookistar's Avatar
i run mine on about 28/30psi
Autoguide.com
Old 16th April 2009, 04:42 PM   #6 (permalink)
jae
jae's Avatar
I'll let you know how it goes.
Theoretically 36f/34r using the base calculation, but I added compensation for fat bloke at the wheel, which may be unnecessary unless car is four up with a bootfull.
If you're on 18s, Mook, you really should try 34 front & 32 rear. Seriously.
My publishing:
My writing:
Old 16th April 2009, 04:52 PM   #7 (permalink)
Site Admin.
Mookistar's Avatar
are those cold pressures?
Autoguide.com
Old 16th April 2009, 04:55 PM   #8 (permalink)
ru'
ru' is is meh!
ru''s Avatar
Cars owned: M3 'Vert & X90
fwiw 34f/32r is what I use (cold, 275/35/18).
...Even now, when eating cereal out of the bowl I expect it to shatter and take out the rest of the building !:eek:
Old 16th April 2009, 04:57 PM   #9 (permalink)
jae
jae's Avatar
Yes.
My publishing:
My writing:
Old 16th April 2009, 05:04 PM   #10 (permalink)
Site Admin.
Mookistar's Avatar
and to think i took air out at the nurburgring
Autoguide.com
Old 16th April 2009, 05:10 PM   #11 (permalink)
Alan is Glad he survived Spa and the Ring in Aug 2011/2013/2016/2018 and is Planning The 2019 Trip
Alan's Avatar
Cars owned: GTROC 0018 I.C.E'd. & White. Suzuki Hayabusa Turbo! R33GTR MY12 GTR
My 33 on Road 30 all round on track they are set around 24/26 Cold
Never had any wear probs
I agree with Mook 38 is just to High
My bike,s got more BHP than most!!!!
Don't make me get the bike out YOU WILL LOSE!!!
Alan is offline   Reply With Quote
Old 16th April 2009, 06:01 PM   #12 (permalink)
jae
jae's Avatar
Even on 19's with 30 profile? Hmmm. I may run it the other way over, start at 36f/34r and see how I do.
My publishing:
My writing:
Old 16th April 2009, 09:37 PM   #13 (permalink)
ru'
ru' is is meh!
ru''s Avatar
I'd imagine track use is totally different from road use; I'd expect much more heating on track (although with the way jae drives this may not be true )
Old 17th April 2009, 02:22 AM   #14 (permalink)
Alan's Avatar
Forgot to say i,m on 18,s as well 265s
Old 17th April 2009, 09:37 AM   #15 (permalink)
NISFAN is on a dyno............. a human dyno :)
NISFAN's Avatar
As this equation does not have a tyre size compensation, I would think the author is talking about standard size tyres. Smaller (narrower) tyres need more pressure, therefore I would expect most performance cars to use lower pressures than the guide suggests.
Old 17th April 2009, 10:02 AM   #16 (permalink)
mifn21 is unaware they can edit their status
You should ALWAYS lower the pressures when on track
Old 17th April 2009, 10:24 AM   #17 (permalink)
moleman's Avatar
Don't agree with that. Seen too many pics of cars cornering hard practically on the rims because air has been let out.
Had a long discussion about with Colin CATDT at the Nurburgring.
Registration
Old 17th April 2009, 10:27 AM   #18 (permalink)
Pressure goes up with temperature - if you leave your pressures the same as on the road and they're on the highside the tyres will overheat due to be worked a lot harder than they would be on the road
10 years of bike trackdays taught me that I doubt cars work different in that respect
We're talking 2-3psi max here, but its enough to make a difference
Old 17th April 2009, 10:43 AM   #19 (permalink)
moleman's Avatar
I'll take your 10 years of track days and raise it with Colin's 30 years of industry testing and what it's taught him.
You don't let air out. You run the car with road pressure, then when hot, you check it's not too high and let air out if it is.
Registration
Old 17th April 2009, 11:01 AM   #20 (permalink)
It will almost always be too high if you're running your usual road pressures and you're driving hard on track, especially with normal tyres
I use one of those gun things you point at the tyre to get the readings
