Checking error codes - Page 2 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Go Back   GT-R Register - Nissan Skyline and GT-R Drivers Club forum > General > Nissan GT-R > Technical Chat
Old 3rd February 2013, 03:39 PM   #21 (permalink)
enshiu's Avatar
P0797 here last week. Seems there is more to adjust on the clutch baskets.
Now: R35 GTR JDM - R32 GTS4
Past: R33 GTR sgl turbo
Old 28th June 2014, 10:47 PM   #22 (permalink)
gtr mart is fast and loud
gtr mart's Avatar
this was never made a sticky as per original requests - can it be please? Would certainly be useful to have to hand.
Old 22nd August 2015, 08:32 PM   #23 (permalink)
dinny is CLUB MEMBER
dinny's Avatar
Originally Posted by [email protected] View Post
ok so you've got an AccessPORT it does cool map stuff
it also reads error codes, same as a consult III & carmate (£1,500)
How many people checking these ? some (DTC) can effect your cars performance
Here's what they mean:
In some cases it could save your 35 going to your HPC
as a heads up C1113 and P0700 aren't nice one's to get
Suspension codes E-SUS, U1000, C1d04, C1d05, C1d06 are very very common, do not be concerned. When you engine is running at high RPM the ECU has more important things to do then to tell the E-SUS what temp the motor is runnnig at and E-SUS thinks that the ECU is not there.
It cant load the nismo transmission software?????
dinny is offline   Reply With Quote
Old 31st January 2016, 06:40 PM   #24 (permalink)
Sam McGoo is unaware they can edit their status
Sam McGoo's Avatar
Found this list while looking for some codes, so thought I'd share it here for reference.
B1001, B1002, B1003, B1004, B1005 DIAGNOSIS SENSOR UNIT
B1006, B1007, B1008, B1009, B1010 DIAGNOSIS SENSOR UNIT
B1011, B1012, B1013, B1014, B1015 DIAGNOSIS SENSOR UNIT
B1017, B1020, B1021 OCCUPANT SENS C/U
B1018 OCCUPANT SENS
B1022 OCCUPANT SENS C/U
B1023 PASS A/B INDCTR CKT
B1026, B1027, B1028, B1029, B1030, B1031 DIAGNOSIS SENSOR UNIT
B1033, B1034 CRASH ZONE SEN
B1035, B1036 CRASH ZONE SEN
B1042, B1043, B1044, B1045, B1046, B1047 DIAGNOSIS SENSOR UNIT
B1049, B1054 DRIVER AIRBAG MODULE
B1050, B1055 DRIVER AIRBAG MODULE
B1051, B1056 DRIVER AIRBAG MODULE
B1052, B1057 DRIVER AIRBAG MODULE
B1058, B1059, B1060, B1061, B1062, B1063 DIAGNOSIS SENSOR UNIT
B1065, B1070 ASSIST A/B MODULE
B1066, B1071 ASSIST A/B MODULE
B1067, B1072 ASSIST A/B MODULE
B1068, B1073 ASSIST A/B MODULE
B1074, B1075, B1076, B1077, B1078, B1079 DIAGNOSIS SENSOR UNIT
B1081 PRE-TEN FRONT RH
B1082 PRE-TEN FRONT RH
B1083 PRE-TEN FRONT RH
B1084 PRE-TEN FRONT RH
B1086 PRE-TEN FRONT LH
B1087 PRE-TEN FRONT LH
B1088 PRE-TEN FRONT LH
B1089 PRE-TEN FRONT LH
B1106, B1107, B1108, B1109, B1110, B1111 DIAGNOSIS SENSOR UNIT
B1113, B1114 SATELLITE SENS RH
B1115, B1116 SATELLITE SENS RH
B1118, B1119 SATELLITE SENS LH
B1120, B1121 SATELLITE SENS LH
B1122, B1123, B1124, B1125, B1126, B1127 DIAGNOSIS SENSOR UNIT
B1129 SIDE MODULE RH
B1130 SIDE MODULE RH
B1131 SIDE MODULE RH
B1132 SIDE MODULE RH
B1134 SIDE MODULE LH
B1135 SIDE MODULE LH
B1136 SIDE MODULE LH
B1137 SIDE MODULE LH
B1138, B1139, B1140, B1141, B1142, B1143 DIAGNOSIS SENSOR UNIT
B1145 CURTAIN MODULE RH
B1146 CURTAIN MODULE RH
B1147 CURTAIN MODULE RH
B1148 CURTAIN MODULE RH
B1150 CURTAIN MODULE LH
B1151 CURTAIN MODULE LH
B1152 CURTAIN MODULE LH
B1153 CURTAIN MODULE LH
B1202, B1203, B1204, B1205, B1206, B1207 DIAGNOSIS SENSOR UNIT
B1209 FRONTAL COLLISION DETECTION
B1210 SIDE COLLISION DETECTION
B2013 ID DISCORD, IMMU-STRG
B2014 CHAIN OF STRG-IMMU
B2098 IGNITION RELAY ON STUCK
B2099 IGNITION RELAY OFF STUCK
B2108 STEERING LOCK RELAY
B2109 STEERING LOCK RELAY
B210A STEERING LOCK CONDITION SWITCH
B210B STARTER CONTROL RELAY
B210C STARTER CONTROL RELAY
B210D STARTER RELAY
B210E STARTER RELAY
B210F PNP/CLUTCH INTERLOCK SWITCH
B2110 PNP/CLUTCH INTERLOCK SWITCH
B2190 NATS ANTENNA AMP.
B2191 DIFFERENCE OF KEY
B2192 ID DISCORD, IMMU-ECM
B2193 CHAIN OF ECM-IMMU
B2205 VEHICLE SPEED
B2267 ENGINE SPEED
B2268 WATER TEMP
B2321, B2322 OIL LEVEL SENSOR
B2553 IGNITION RELAY
B2555 STOP LAMP
B2556 PUSH-BUTTON IGNITION SWITCH
B2557 VEHICLE SPEED
B2560 STARTER CONTROL RELAY
B2562 LOW VOLTAGE
B2578, B2579 IN-VEHICLE SENSOR
B257B, B257C AMBIENT SENSOR
B2581, B2582 INTAKE SENSOR
B2601 SHIFT POSITION
B2602 SHIFT POSITION
B2603 SHIFT POSITION STATUS
B2604 PNP SWITCH
B2605 PNP SWITCH
B2606 STEERING LOCK RELAY
B2607 STEERING LOCK RELAY
B2608 STARTER RELAY
B2609 STEERING STATUS
B260A IGNITION RELAY
B260B STEERING LOCK UNIT
B260C STEERING LOCK UNIT
B260D STEERING LOCK UNIT
B260F ENGINE STATUS
B2612 STEERING STATUS
B2614 ACC RELAY
B2615 BLOWER RELAY CIRCUIT
B2616 IGNITION RELAY CIRCUIT
B2617 STARTER RELAY CIRCUIT
B2618 BCM
B2619 BCM
B261A PUSH-BUTTON IGNITION SWITCH
B261E VEHICLE TYPE
B2621 INSIDE KEY ANTENNA 1
B2622 INSIDE KEY ANTENNA 2
B2623 INSIDE KEY ANTENNA 3
B2630, B2631 SUNLOAD SENSOR
B2632, B2633 AIR MIX DOOR MOTOR PBR (DRIVER SIDE)
B2634, B2635 AIR MIX DOOR MOTOR PBR (PASSENGER SIDE)
B2636, B2637, B2638, B2639, B2654, B2655 MODE DOOR MOTOR
B263D B263E, B263F, B2656 INTAKE DOOR MOTOR
B26E7 TPMS CAN COMM
B26E9 STEERING STATUS
B26EA KEY REGISTRATION
C1101, C1102, C1103, C1104 WHEEL SENSOR
C1105, C1106, C1107, C1108 WHEEL SENSOR
C1109 POWER AND GROUND SYSTEM
C1110 ABS ACTUATOR AND ELECTRIC UNIT (CONTROL UNIT)
C1111 ABS MOTOR, MOTOR RELAY SYSTEM
C1113, C1145, C1146 YAW RATE/SIDE/DECEL G SENSOR
C1115 WHEEL SENSOR
C1116 STOP LAMP SWITCH
C1120, C1122, C1124, C1126 IN ABS SOL
C1121, C1123, C1125, C1127 OUT ABS SOL
C1130 ENGINE SIGNAL
C1140 ACTUATOR RELAY SYSTEM
C1142 PRESS SENSOR
C1143 STEERING ANGLE SENSOR
C1144 STEERING ANGLE SENSOR ADJUSTMENT
C1155 BRAKE FLUID LEVEL SWITCH
C1160 DECEL G SENSOR CALIBRATION
C1162 PRESSURE SENSOR CALIBRATION
C1164, C1165 CV SYSTEM
C1166, C1167 SV SYSTEM
C1193 VALVE CALIBRATION
C1201 AWD CONTROL UNIT
C1203 ABS ACTUATOR AND ELECTRIC UNIT (CONTROL UNIT)
C1204 AWD SOLENOID
C1205 AWD ACTUATOR RELAY
C1210 ECM
C1704, C1705, C1706, C1707 LOW TIRE PRESSURE
C1708, C1709, C1710, C1711 TRANSMITTER (NO DATA)
C1716, C1717, C1718, C1719 TRANSMITTER (PRESSDATA)
C1720, C1721, C1722, C1723 TRANSMITTER
C1728 RECEIVER ID
C1729 VEHICLE SPEED SIG ERR
C1730, C1731, C1732, C1733 FLAT TIRE
C1750, C1751, C1752, C1753 RECEIVER
C1754 LOW TIRE PRESSURE WARNING CONTROL UNIT
C1755, C1756, C1757, C1758 POOR RECEIVING CONDITIONS
C1D01 VEHICLE SPEED SIGNAL
C1D02 YAW RATE/SIDE/DECEL G SENSOR
C1D03 STEERING ANGLE SENSOR
C1D04, C1D05 TORQUE SIGNAL
C1D06 ENGINE SPEED SIGNAL
C1D07 STOP LAMP SWITCH
C1D08 ABS ACTUATOR AND ELECTRIC UNIT (CONTROL UNIT)
C1D09 BRAKE FLUID PRESSURE SIGNAL
C1D10 FRONT VERTICAL G SENSOR
C1D11 REAR VERTICAL G SENSOR
C1D12 SHOCK ABSORBER ACTUATOR
C1D13 SHOCK ABSORBER ACTUATOR
C1D14 SHOCK ABSORBER ACTUATOR
C1D15 SHOCK ABSORBER ACTUATOR
C1D16 CONTROL UNIT
C1D17 BATTERY POWER SUPPLY
C1D19, C1D20 MODE SWITCH
C1D21, C1D22 MODE LAMP
C1D23 CONTROL UNIT
P0011, P0021 IVT CONTROL
P0031, P0032, P0051, P0052 A/F SENSOR 1 HEATER
P0037, P0038, P0057, P0058 HO2S2 HEATER
P004A, P004C, P004D TC BOOST CONTROL SOLENOID VALVE
P0075, P0081 IVT CONTROL SOLENOID VALVE
P0101, P010B MAF SENSOR
P0102, P0103, P010C, P010D MAF SENSOR
P0112, P0113 IAT SENSOR
P0116 ECT SENSOR
P0117, P0118 ECT SENSOR
P0122, P0123, P0227, P0228 TP SENSOR
P0125 ECT SENSOR
P0127 IAT SENSOR
P0128 THERMOSTAT FUNCTION
P0130, P0150 A/F SENSOR 1
P0131, P0151 A/F SENSOR 1
P0132, P0152 A/F SENSOR 1
P0133, P0153 A/F SENSOR 1
P0137, P0157 HO2S2
P0138, P0158 HO2S2
P0139, P0159 HO2S2
P0171, P0174 FUEL INJECTION SYSTEM FUNCTION
P0172, P0175 FUEL INJECTION SYSTEM FUNCTION
P0181 FTT SENSOR
P0182, P0183 FTT SENSOR
P0196 EOT SENSOR
P0197, P0198 EOT SENSOR
P0222, P0223, P2132, P2133 TP SENSOR
P0234, P1334 TC SYSTEM
P0236, P0240 TC BOOST SENSOR
P0237, P0238, P0241, P0242 TC BOOST SENSOR
P0300, P0301, P0302, P0303, P0304, P0305, P0306 MISFIRE
P0327, P0328, P0332, P0333 KS
P0335 CKP SENSOR (POS)
P0340, P0345 CMP SENSOR (PHASE)
P0411 SECONDARY AIR INJECTION SYSTEM
P0420, P0430 THREE WAY CATALYST FUNCTION
P0441 EVAP CONTROL SYSTEM
P0442 EVAP CONTROL SYSTEM
P0443 EVAP CANISTER PURGE VOLUME CONTROL SOLENOID VALVE
P0444, P0445 EVAP CANISTER PURGE VOLUME CONTROL SOLENOID VALVE
P0447 EVAP CANISTER VENT CONTROL VALVE
P0448 EVAP CANISTER VENT CONTROL VALVE
P0451 EVAP CONTROL SYSTEM PRESSURE SENSOR
P0452 EVAP CONTROL SYSTEM PRESSURE SENSOR
P0453 EVAP CONTROL SYSTEM PRESSURE SENSOR
P0455 EVAP CONTROL SYSTEM
P0456 EVAP CONTROL SYSTEM
P0460 FUEL LEVEL SENSOR
P0461 FUEL LEVEL SENSOR
P0462, P0463 FUEL LEVEL SENSOR
P0491, P0492 SECONDARY AIR INJECTION SYSTEM
P0500 VSS
P0506 ISC SYSTEM
P0507 ISC SYSTEM
P0550 PSP SENSOR
P0603 ECM POWER SUPPLY
P0605 ECM
P0607 ECM
P062A SUB FUEL PUMP
P0643 SENSOR POWER SUPPLY
P0700 TCM
P0705 RANGE SENSOR POWER SUPPLY
P0706 RANGE SENSOR
P0710 FLUID TEMPERATURE SENSOR
P0711 FLUID TEMPERATURE SENSOR FUNCTION
P0715 CLUTCH A SPEED SENSOR
P0720 OUTPUT SHAFT SPEED SENSOR
P0725 ENGINE SPEED SIGNAL
P0729 SLEEVE A1 FUNCTION
P0731 SLEEVE B1 FUNCTION
P0732 SLEEVE A2 FUNCTION
P0733 SLEEVE B2 FUNCTION
P0745 CLUTCH A SOLENOID VALVE
P0746 CLUTCH A SOLENOID VALVE FUNCTION
P0750 SHIFT SOLENOID VALVE 1
P0755 SHIFT SOLENOID VALVE 2
P0760 SHIFT SOLENOID VALVE 3
P0765 SHIFT SOLENOID VALVE 4
P0770 SEQUENCE SOLENOID VALVE
P0775 CLUTCH B SOLENOID VALVE
P0776 CLUTCH B SOLENOID VALVE FUNCTION
P0790 SET-UP SWITCH (TRANSMISSION)
P0795 AXIS A FEED PRESSURE SOLENOID VALVE
P0797 AXIS A FEED PRESSURE SOLENOID VALVE FUNCTION
P0827, P0828 AUTO/MANUAL RANGE CHANGE SWITCH
P0840 CLUTCH A PRESSURE SENSOR
P0845 CLUTCH B PRESSURE SENSOR
P0850 PNP SWITCH
P0872, P0873 LINE PRESSURE SENSOR
P0882 TCM POWER SUPPLY
P1148, P1168 CLOSED LOOP CONTROL
P1211 TCS CONTROL UNIT
P1212 TCS COMMUNICATION LINE
P1217 ENGINE OVER TEMPERATURE
P1220 FUEL PUMP CONTROL MODULE (FPCM)
P1225, P1234 TP SENSOR
P1226, P1235 TP SENSOR
P1233, P2101 ELECTRIC THROTTLE CONTROL FUNCTION
P1236, P2118 THROTTLE CONTROL MOTOR
P1238, P2119 ELECTRIC THROTTLE CONTROL ACTUATOR
P1239, P2135 TP SENSOR
P1263, P2263 TC SYSTEM
P1290, P2100, P2103 THROTTLE CONTROL MOTOR RELAY
P1421 COLD START CONTROL
P1564 ASCD STEERING SWITCH
P1572 ASCD BRAKE SWITCH
P1574 ASCD VEHICLE SPEED SENSOR
P1610 LOCK MODE
P1611 ID DISCORD, IMMU-ECM
P1612 CHAIN OF ECM-IMMU
P1614 CHAIN OF IMMU-KEY
P1615 DIFFRENCE OF KEY
P1705 ACCELERATOR PEDAL POSITION SIGNAL
P1805 BRAKE SWITCH
P1826 TRANSFER FLUID TEMPERATURE
P2122, P2123 APP SENSOR
P2127, P2128 APP SENSOR
P2138 APP SENSOR
P2432, P2433 SECONDARY AIR INJECTION SYSTEM MAF SENSOR
P2440, P2442 AIR CUT SOLENOID VALVE
P2713 AXIS B FEED PRESSURE SOLENOID VALVE
P2714 AXIS B FEED PRESSURE SOLENOID VALVE FUNCTION
P2722 LUBRICATING FLOW SOLENOID VALVE
P2731 LINE PRESSURE SOLENOID VALVE
P2765 CLUTCH B SPEED SENSOR
P2776 PADDLE SHIFTER (SHIFT-UP SWITCH)
P2780 PADDLE SHIFTER (SHIFT-DOWN SWITCH)
P2A00, P2A03 A/F SENSOR 1
U0101 CAN COMM CIRCUIT
U0164 CAN COMM CIRCUIT
U0415 VEHICLE SPEED SIG
U1000 CAN COMM CIRCUIT
U1000, U1002 CAN COMM CIRCUIT
U1010 CONTROL UNIT (CAN)
U1200 AV CONTROL UNIT
U1201 AV CONTROL UNIT
U1202 AV CONTROL UNIT
U1204 GPS
U1204 GPS
U1205 GPS
U1205 GPS
U1206 GPS
U1206 GPS
U1207 GPS
U1207 GPS
U1216 AV CONTROL UNIT
U1217 AV CONTROL UNIT
U1218 AV CONTROL UNIT
U1219 AV CONTROL UNIT
U121A AV CONTROL UNIT
U121B AV CONTROL UNIT
U121C AV CONTROL UNIT
U121D AV CONTROL UNIT
U121E AV CONTROL UNIT
U121F AV CONTROL UNIT
U1220 AV CONTROL UNIT
U1243 DISPLAY UNIT
U1243 DISPLAY UNIT
U1244 GPS ANTENNA
U1244 GPS ANTENNA
U1258 SATELLITE RADIO ANTENNA
U1310 AV CONTROL UNIT
Sam McGoo is offline   Reply With Quote
Old 1st February 2016, 10:17 AM   #25 (permalink)
GT-RDC Founder Member
barry P.'s Avatar
Sam, what codes did you have show up on yours when you checked? Clear any that appear, go for a drive and recheck.
