#441 (permalink) | |
Mycroft
#442 (permalink) |
Mycroft
To repeat, you said things only got worse from the moment you added any weight to the tyre, I said that is not true and subsequently I have been proven correct, you were wrong, you are wrong and you are prepared to twist, squirm, doctor, in fact do almost anything to avoid losing face in such a spectacular way.
#443 (permalink) |
SDB
This is a shame. I'm dissapointed.
It shows that you actually REALLY don't understand, and are not just being awkward. So, unfortunately I've lost interest now and will go home ready for the start of Leg 3 of Rally Finland tomorrow morning. If in the mean time anyone is to post that they think mycroft is correct, I will be happy to answer any questions tomorrow. Otherwise, I can't see any interest or challenge in this conversation. All the best Simon
#445 (permalink) | |
Mark Ayling
Cars owned: Supra TT
Mark Ayling MKIV Supra TT6 Veilside To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#446 (permalink) |
Evosareslow
What's the point of this thread anyway?
When you double the load on a tyre, you increase the grip by 90% or 100% or 110% or something around those values, from what you say. Why would any mature man have an online discussion for over thirty pages on the subject?
#447 (permalink) |
JPaaso
Cars owned: R32 GT-R
Let y=f(x)=ax+b.
f(2x) = a(2x)+b = 2(ax)+b. HTH. edit: (some clarification) If you have b=0 you exactly double y when you double x which should be pointed out by my silly use of parenthesis. If you have b<>0 you do not exactly double y for each doubling of x but that is merely a case of offsetting the line. - JjP
"It is better to make torque at high rpm than at low rpm, because you can take advantage of gearing." Last edited by JPaaso; 9th August 2003 at 07:03 PM.. |
#448 (permalink) |
Mycroft
''Why would any mature man have an online discussion for over thirty pages on the subject?''
Evos'r'slo, there's the rub, that assumption of maturity is founded on some rocky ground. I'm just having a laugh at the expense of a twonk. Mark, not pathetic, shatteringly funny! So, in answer to the question:- ''Could you tell us all when a disc brake has a pad with a Co-eff friction of 0.45 and is slowed down by it does it mean, assuming flat ground, when the driver has stopped and is holding the car stationary with his foot on the brake, is that same co-eff or is it infinite?'' The answer is as follows. 1/. When the pad is sitting there it has the same co-eff as it always had, so the pad has 0.45 still. 2/. However, when the vehicle is stationary there is in fact a co-efficient of '0' acting on the disc, it has no movement! 3/. What you do have is a clamping force in place and that acts only in the direction it is apllied and sees no movement, it too has no friction except the minute 'searching' force that is called conformity, this is small enough to be ignored.
#449 (permalink) | |
Mycroft
#450 (permalink) |
Mycroft
Isn't nature wonderful.
The simple answer to all that is that if you have been braking and come to a halt the whole thing returns to '0'. No 'infinite' or near infinite' or anything else, just simple, perfect, beautiful null. OK, we now know that certain cherished and accepted notions can be as reliable as guessing the weight of a fat bloke in a Hall of Mirrors. ![]()
#451 (permalink) |
LSR
Talk about trying to achieve the world's longest thread with a subject, and not random postings as elsewhere.
I can't believe you people are still going on about this, arguing over the internet about something that won't have much impact on your overall life, except for bragging rights, seems pointless to me.
#453 (permalink) |
LSR
When I said argument, I meant you have different beliefs over a concept in car handling/dynamics, or whatever you wanna call it, and you present your points, introducing different concepts/ideas to support that. I meant a civilised argument.
#454 (permalink) |
SDB
LSR
The reason it's gone on this long is that I was asked to add balance to this discussion, and take it very seriously if someone is giving incorrect information on a thread I have posted on. Evosareslow The reason for the discussion is that if it doubles, adding mass to a car would not slow it down, but if it does double, the entire rest of vehicle dynamics technology works. All the best Simon
#455 (permalink) | |
SDB
and as that should just be a 1 liner, I'll go on to the rebound and rebound rate thing... which should be fun. So tell me Mycroft. Could you please in simple one line descriptions, define rebound, and then rebound rate as you understand them to be? Cheers Simon
#456 (permalink) | |
SDB
Just a few other things to ask you Mycroft.
Firstly... You asked this.. Quote:
Secondly.. As your words have been proven to mean nothing. I would be very interested in any documented proof you have the the friction coefficient becomes zero once the car has stopped. This sounds like a load of utter 'mycroft' to me, but I am STILL quite willing to be proven wrong. My personal thoughts are that the Static Friction Coefficient is the measure of how much resistance the surfaces offer to "starting to move" (if you like) and the kinetic friction coefficient is a measure of how much resistance the surfaces offer to "continuing to move", or how much they try to stop the movement. In which case, I cannot see how either of those change in any way by stopping the car. Thirdly... You now agree that adding mass to a car, ultimately reduces it's cornering performance, right? But you still think that the tyres are able to double their effort with doubling of load? right? So, could you please explain exactly WHY adding mass to a car reduces its cornering performance? Cheers Simon
#458 (permalink) | |
SDB
Isn't it strange how many people tell you that you are making a fool of yourself, and yet you are the only one telling me? Don't worry Mycroft, you're right and they're ALL wrong ![]() Are you likely to answer those questions? Didn't think so.
#459 (permalink) | ||
Mycroft
I only see a series of posts that ramble on about being called into service of the greater good [hahaha], another mis-quote of my posts [how many times now???], a further distraction to steer everyone away from the fact that for the fifth time you have been wrong [that's 0/5 Simon] so really matey you have nowhere to go with this... except down... Could you post a link to the thread where you say you were 'invited' over to here to make a fool of yourself? Whoever it was, was doing you the biggest dis-service ever! Are you familiar with the term 'Judas Goat'?
#460 (permalink) |
SDB
Is it just me, or does everyone feel embarrased for Mycroft now? It was funny for a while, but now it's just dull.
If anyone else wants the link to the thread, I'll post it up. If anyone is still reading this, would they be good enough to let us know whether Mycroft still holds any credibility in their eyes, and whether they think there is anything we've been arguing about that mycroft has the upper hand on? All the best Simon
Bookmarks |
Thread Tools | |
