RB26 Inlet/plenum removal with pics - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree6Likes
Old 15th March 2010, 09:33 PM   #1 (permalink)
carswaps is looking for a Skyline!
carswaps's Avatar
RB26 Inlet plenum removal,
After looking around various forums for a 'How to' on the removal of the RB26 plenum i thought i would do one ...hope this helps you out....Maybe Mr Mod will make this a 'Sticky'
Firstly dont be daunted by the job as its not that bad....
Bag all your bits/nut etc and if you think you wont remember where something went take pics!
A couple of tools i found invaluable:
A small socket set with both deep and short sockets, wobble extension, long & short extensions, Long nose pliars and a long piece of welding rod for the nuts and washers you WILL drop!
Please feel free to voice your opinion and help others.
1: Remove the throttle cable, mechanism & all pipe work/ connectors you can see connected to the top of the plenum.
2: Cable tie the throttle arms out of the way.
3: Remove the front intercooler pipe from the front of the plenum, remove the fuel filter bracket.
4: remove the fuel lines......NO SMOKING as the feed pipe will be under pressure and some fuel will leak!
The steel fuel pipe/bracket is held to the underside of the plenum with 3 x 10mm bolts.
5: Next remove the 4 x 10mm bolts from the IAC valve and the 4 rubber pipes to the left of it......this can be fun as the clips will be the wrong way around to grab hold with pliars...There is also an electrical connector attached to the IAC.
6: Next remove the 3 x 12mm bolts that fasten vertically to the underside of the plenum, the 1st pic shows bolt number 1 number 2 is opposite on the other side and 3 is rear right as the later pic shows.
you cant take bolt number 1 out without removing the oil filter...however you dont need to take it fully out to remove the plenum!
7: Next remove the 5x 10mm bolts that hold the Y pipe on the underside of the plenum.......Its a bit fiddley but i,ve shown you a before and after pic so you can see where its attached.
8: Remove this Bracket/pipe attached to the bulkhead
9: You should now be at the point to remove the 12 x 12mm plenum nuts/washers
The top 6x and bottom 3 nuts are easy.
If your plenum is painted or polished use something under the socket to protect...this obviously applies on refitting.
The 4th nut along the bottom needs short socket extension, wobble bar and short socket.....you also need to go between the pipes to access the nut
The last bottom nut (next to the bulkhead) needs short extension and short socket.
10: After all nuts are off slide the plenum off....you may need to tap it to break the seal.
Be very carefull of the steel collers as they can drop into oblivion!!!
The throttle bodies will just slide off also....if this is the 1st time they have been off the gaskets will be knackered so replace with new and ideally uprated steel ones.
Whilst the throttle bodies are off its fine to clean them externally but DO NOT clean the inner butterfly or port as it will not seal properly and you will end up with poor idling!
After you have removed the plenum replace as many water pipes as you can!
If nothing else replace these 4!
I thought they looked ok and left it....a week later the plenum had to come off again to replace them due to a leak....dont skimp on time do it right the first time (i wish i had)
And that it....i really cant stress how important it is to replace those water pipes.
Top tip for refitting get 12x 12mm bolts and nuts/washers and superglue them together and they will go on all in one...easy lol
Cheers Steve
carswaps is offline   Reply With Quote
Old 16th March 2010, 07:36 AM   #2 (permalink)
Austrian GTR is now EFR boosted
Austrian GTR's Avatar
Cars owned: CX5 CD175 Revolution Top, R32 GTR
That's obviously one of the best plenum removal instructions that has ever been posted
Leo
My GTR
Austrian GTR is offline   Reply With Quote
Old 16th March 2010, 06:54 PM   #3 (permalink)
ANDY GTR is Back on the road
ANDY GTR's Avatar
Cars owned: R33 GTR R34 GT/t Toyota Landcruiser 3.0
will be takeing mine off soon thanks for the info
ANDY GTR is offline   Reply With Quote
Old 16th March 2010, 06:59 PM   #4 (permalink)
minifreak is Without a skyline!
minifreak's Avatar
Good on you for going to the trouble to post up a guide. Ive done it different by removing less but thats a good write up
Who needs a Skyline when you can have a Tro!!
Metro power rules the GTROC Slalom ;)
minifreak is offline   Reply With Quote
Old 16th March 2010, 07:02 PM   #5 (permalink)
fourtoes is milk monitor
fourtoes's Avatar
So good i think you might find people taking their plenums off just for fun now!
nice one buddy, about time someone did this!
bob
Like us on Facebook ZEALOU5 turning cars into heroes.
ZEALOU5
Please Whatsapp me on 07970699470.
(^^^best way to get in touch tbh^^^).
Contact: Bobby Proctor
Mobile: 07970699470
Website:
Email:
Old 16th March 2010, 08:12 PM   #6 (permalink)
carswaps's Avatar
I have to say that i got more help from Bob/fourtoes than anyone else.
Information is free but it seems hard to gain on some forums!
Thanks Bob ...love your rebuild thread....Virtual shaking of hand mate
Old 16th March 2010, 10:04 PM   #7 (permalink)
fourtoes's Avatar
Delighted to be able to help in some way buddy!
Cheers for the comments, and btw your engine looks superb in gold!!!
Great work mate.
bob
ZEALOU5
Mobile: 07970699470
Website:
Email:
Old 16th March 2010, 10:52 PM   #8 (permalink)
33 vspec is festive
33 vspec's Avatar
Cars owned: r33 gtr vspec
Great write up mate.
It has to be said though its an absolute pig of a job.
I've done it 3 times and i really hate it.Scraped hands and knuckles and magnets are the order of the day.
33 vspec is offline   Reply With Quote
Old 16th March 2010, 11:21 PM   #9 (permalink)
GT-R Glenn's Avatar
Yep, well done.
Its a pig of a job on an stock car, like taking the rear hairdryer off.
I dont run the factory oilfilter stuff or the factory idle control, so I can just reach everything with a 12mm ring spanner, takes 5 minutes to get mine off.
Old 16th March 2010, 11:23 PM   #10 (permalink)
33 vspec is festive
33 vspec's Avatar
Originally Posted by GT-R Glenn View Post
Yep, well done.
Show off.
Old 17th March 2010, 01:20 AM   #11 (permalink)
Sub Boy is a nana driver
Sub Boy's Avatar
Yep, well done.
I see a few engines being built that don't run all the AAC Valve rubbish...Next time I have the motor out (Prob to build the RB30) I will take it off.
....Will the Power FC (Std with AFM's) run OK without the idle controls?
Old 17th March 2010, 01:50 AM   #12 (permalink)
GT-R Glenn's Avatar
yes
Old 17th March 2010, 02:33 AM   #13 (permalink)
ru'
ru' is is meh!
ru''s Avatar
Cars owned: M3 'Vert & X90
Brilliant write up
...Even now, when eating cereal out of the bowl I expect it to shatter and take out the rest of the building !:eek:
Old 17th March 2010, 03:52 AM   #14 (permalink)
Sub Boy's Avatar
yes
Cool, Will ring you when I do it.....Might be a while yet though!
Old 17th March 2010, 08:02 AM   #15 (permalink)
syclone is now diffusered.
syclone's Avatar
Cars owned: 2001 R34 GT-R, 2011 R35 GT-R
done this myself and could only get crappy pictures.
yours are excellent and also the instructions are on the spot. should be stickied.
R34 is only a little different in detail, so these instructions will work for it as well.
syclone is offline   Reply With Quote
Old 17th March 2010, 09:26 PM   #16 (permalink)
dwood is misses his 32 gtr but ok with gtst
Cars owned: 33 gtst.
nice one carswaps.
i have done mine several times. and that is a good step by step removal.
i do some bits different to you but its 90% the same.
and its best to have a patient head on when you do decide to remove or spanners will end up flying. lolololo
dwood is offline   Reply With Quote
Old 25th July 2010, 10:01 PM   #17 (permalink)
NerdJuice is Dreaming of an RB30...
NerdJuice's Avatar
Thanks very much for the write up! I'm in the process of removing mine and this is helping me a lot. Any chance the pics could be re uploaded? Thread isn't TOO old.
NerdJuice is offline   Reply With Quote
Old 30th July 2010, 04:44 PM   #18 (permalink)
nozza1 is Wanting to work on his gtr!!!!!
nozza1's Avatar
Cars owned: Honda civic LSI - Audi-Ur Quattro - Lancia Intergrale EvoII - Kawasaki Ninja zx7r - R34gtr V-Spec - P2 v70 D5
wheres all the pictures gone!!!!
Been looking for a thread like this for ages.
AUDI QUATT TURBS 20V, LANCIA INTERGRALE EVO 2, GOLF TDI ANNIVERSARY CHIPPED 250 BHP, KAWASAKI ZX7R
nozza1 is offline   Reply With Quote
Old 30th July 2010, 04:55 PM   #19 (permalink)
drewzer is going RB30 soon!
Banned
as mentioned can you upload the pictures again?
cheers
drewzer is offline   Reply With Quote
Old 30th July 2010, 10:03 PM   #20 (permalink)
MS33 is unaware they can edit their status
MS33's Avatar
Great thread, but can you upload the pictures again.
MS33 is offline   Reply With Quote
