Blocked rainwater drainage channel under boot lid - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Go Back   GT-R Register - Nissan Skyline and GT-R Drivers Club forum > General > Nissan GT-R > Technical Chat
Old 19th May 2010, 09:30 PM   #1 (permalink)
mls
mls is unaware they can edit their status
mls's Avatar
Question Blocked rainwater drainage channel under boot lid
Hi my gtr r35 has a blocked drainage channel where the rainwater is supposed to drain away from the boot area. It is the off side and it looks like the water should run away just above the OS light cluster into the wing area and away. There is a plastic cap which does not look easy to remove at the end to the channel. Anyone know of a way to clear this and thus stopping rainwater gathering all around in the channel around the top of the boot opening?
mls is offline   Reply With Quote
Old 19th May 2010, 09:36 PM   #2 (permalink)
Zed Ed is elsewhere, mostly
Zed Ed's Avatar
Cars owned: BRZ track project
remove debris from the gap between light cluster and metal bodywork
I posted on this a while back
had my fun, now I'm off
Zed Ed is offline   Reply With Quote
Old 19th May 2010, 09:39 PM   #3 (permalink)
Zed Ed's Avatar
https://www.gtr.co.uk/forum/119325-wa...oot-seals.html
Old 21st January 2018, 12:34 PM   #4 (permalink)
Chronos's Avatar
Cars owned: R35 Black Edition
Originally Posted by EAndy View Post
Grime builds up between where the bumper join is below and blocks the channel therefore the water builds up, it still shouldn't leak into the boot however.
I use a cable tie and push between the gap and wiggle it to dislodge the grime, you'll then see the water flow free and exit out of the car by the exhausts.
Good tip thanks, all this time and I'd never noticed/heard of this!.. probably as I don't use the boot much.. Anyhow cleaned mine up and cable ties used to clear the drain slits.
Before - blocked+swimming!
After - flowing, cables ties in place as an example, then removed and kept in door basket.
Old 13th March 2018, 06:54 PM   #5 (permalink)
HUNTER76 is unaware they can edit their status
had to do this the other day .a bloody stupid design of a water drain
HUNTER76 is offline   Reply With Quote
Old 28th September 2018, 08:40 AM   #6 (permalink)
Chronos's Avatar
Reminder as winters coming up folks, get those rain channels unclogged and cleared!!
Old 27th February 2019, 07:40 PM   #7 (permalink)
Reano is Looking for Vpower
Got to agree only spotted it by accident when we had heavy rain and I had to go into boot.
Reano is offline   Reply With Quote
Old 2nd September 2019, 06:48 PM   #8 (permalink)
Chronos's Avatar
Reminder as winters coming up folks, get those rain channels unclogged and cleared!! Kitchen roll to scoop the bulk crud in channels, and then run hot water down to loosen the rest, using cable ties to clear the drain slits (bottom+sides)
Old 2nd September 2019, 06:57 PM   #9 (permalink)
Ooo Matron !
snuffy's Avatar
Cars owned: GT-R & Fiat 500
When I had mine wrapped last year at PWPro Paul said he took some foam bits out that mean I no longer have to poke mine with a stick !
MY2013 TCM
ACSpeedtech EcuTek RaceRom 5
Old 2nd September 2019, 07:02 PM   #10 (permalink)
Chronos's Avatar
it's the ends near the boot that get clogged with mud etc, so the water then cannot filter passed the slim slits, and you end up with a mini crud bath... not sure how taking out some foam helps the slits? check yours for us, and see if its clear, and if he's done some kind of modification... taa.
