Hypothetically, My modified R35 has just died... - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 6th April 2011, 06:58 PM   #1 (permalink)
coolmeister is unaware they can edit their status
Cars owned: Current: R35 DMG Black Edition. Previously: 997 S cab, Clio 182, Evo V, Pug 205 gti
Unhappy What happens if my modified R35 engine/gearbox blows up?
(THIS IS A HYPOTHETICAL SITUATION!)
So, I've taken the plunge, and plugged my Cobb AP in, giving me 570hp, fantastic fun until one day I'm driving along and the gearbox/engine/transmission (delete as applicable) blows up. As expected Nissan HPC confirm diagnosis, but politely proceed to tear up my warranty and then direct me towards the door...
From a brief scan of the web, a replacement would be:
engine - £33k+vat
gearbox - £11k+vat
(correct me if I'm wrong)
my question is: would a foocked engine/gearbox etc be repairable by some of our esteemed independents (i.e. GTC, SVM, CPR, Litchfields etc), and how much would it cost? Obviously this would depend on what exactly had gone wrong/broken, but then could people suggest what would be the most likely things to go wrong/break? I'm no engineer (could you guess?), so would value people's opinions and suggestions. We are talking "worst case scenarios" here.
coolmeister is offline   Reply With Quote
Old 6th April 2011, 07:04 PM   #2 (permalink)
blitzman is by the sea.
blitzman's Avatar
Cars owned: BMC & Nissan
If it is so risky tuning an R35 a little bit,with a risk of invalidating a warranty,then why bother?
Either buy the car standard and keep it that way,if your worried about it.
Or buy it,tune it and then deal with,ie PAY for any problems you've encountered.
blitzman is offline   Reply With Quote
Old 6th April 2011, 07:15 PM   #3 (permalink)
AndyBrew is feeling very tired!
AndyBrew's Avatar
Cars owned: Audi A6 Avant 2.0 TDi, Porsche Boxster S, R35 GT-R and F430 Scuderia
an engine maybe 33K but its not like the whole engine will disappear from under your bonnet, so I guess a worst case scenario would be a melted piston or something like that which I wouldn't of thought would be 33K to replace.
personally I think if you have concerns just keep the car standard and enjoy it for what it is, that's what I'm doing, even though I have now got used to the power and have found myself thinking I could do with a bit more LOL!
the more I think about it these cars are so powerful you simply can't use the power they have in standard form 99% of the time, you simply don't have enough room, open it up on a motorway and your talking a prison sentence after 10 seconds or so!
i'm not knocking anybody that has modded as I have modded every previous car I have owned, just this one I am determined to keep standard!
AndyBrew is offline   Reply With Quote
Old 6th April 2011, 07:20 PM   #4 (permalink)
bobel is testing the limits of adhesion
bobel's Avatar
Cars owned: R35, X5
Interesting post there fella!! Think it says it all that it's hypothetic as you will find relatively few threads where GTR's suffer catastrophic failures, but I'll indulge you on this one.....worst case for an engine would be damage to the block there by requiring a completely new engine the most likely cause of this would be if the rod's bend (the bit connecting the piston to the crank) has been known to happen to a handful of cars worldwide but only with relatively high boost levels and I'd imagine your ok with standard stage w power or equivalent, there are of course many other things that could go wrong with the engine but for the vast majority it would only result in the replacement of some components unless your unlucky and something gets sucked into the cylinder but again relatively low likely hood
Right onto the gearbox....probably the weakest link in the GTR setup but still relatively sturdy, in many cases it's software malfunctions that cause issues or minor mechanical gremlins....there have been cases of the cir clips that hold the gear sets in place giving way but I believe this is more an issue for early models and high torque applications, the stock clutches appear to be quite reliable up to 600lb/ft which is a huge slug of torque by any measure, as with anything abuse will increase likely hood of failure and personally if I was running a tune I would limit the amount of launches as shock loading is what causes the real issues on any gearbox.
On the whole despite early scaremongering the GTR is a solid platform...keep it regularly serviced (milage wise anyway as time intervals aren't really relevant unless you go beyond 12mth engine / 24mth gearbox.) at the end of the day to suffer either complete failure would be unlikely and even a HPC will be able to fix singular component failure albeit more costly then a independent but the likely hood of leaving 33k or even 11k with a HPC is low.....enjoy the power and put up a nice review for everyone to enjoy
bobel is offline   Reply With Quote
Old 6th April 2011, 08:50 PM   #5 (permalink)
enshiu's Avatar
call SVM maybe they can refurbish your engine and gearbox.
Old 6th April 2011, 08:54 PM   #6 (permalink)
Nigel-Power is playing a Game
Nigel-Power's Avatar
Cars owned: a wheelbarrow
exactly
Nigel-Power is offline   Reply With Quote
Old 6th April 2011, 08:57 PM   #7 (permalink)
GTRSTAR is talking To Kev @ SVM Because He Can Turn A Two Ton Turd in to Shit Off A Shovel!
GTRSTAR's Avatar
SVM can fix engine and gearbox issues for a FRACTION of the normal replacement cost even by other Independent garages.
09 GTR Black Series:
Cobb AP \ Cobra Imola Carbon Technology Seats \ HRE Comp 90 Wheels \ Titanium Nuts \ Michelin PS2 Tyres \ Performance Friction Discs/Pads \ HEL Brake Lines \ KW V3 Clubsport Coilovers \ Stillen ARB's \ KK12R Under Construction At SVM \
"If it doesnt scare me shitless, it doesnt command respect, if it doesnt command respect, its not worth driving." GTRSTAR 2010
"If it breaks the bank, I lose the wife, if I lose the wife, I've still got the GTR" :D GTRSTAR 2011
GTRSTAR is offline   Reply With Quote
Old 6th April 2011, 09:00 PM   #8 (permalink)
Zed Ed is elsewhere, mostly
Zed Ed's Avatar
Cars owned: BRZ track project
How much can you afford to bin?
At 650 plus there would be more to talk about.
had my fun, now I'm off
Zed Ed is offline   Reply With Quote
Old 6th April 2011, 09:01 PM   #9 (permalink)
David.Yu is adjusting to life without a GT-R...
Cars owned: R35 GT-R, BMW M135i 5 dr manual, 190hp Abarth 500 (wife's)
Way to go posting misleading thread titles...
Do you have any idea how off-putting a thread title like that looks on a forum like this?
If you're scared, keep it standard. And don't post stupid thread titles like that.
David.Yu is offline   Reply With Quote
Old 6th April 2011, 09:02 PM   #10 (permalink)
weetrav is happy the GT-R is back
weetrav's Avatar
Cars owned: R35 GTR Premium Edition
As above.............
"...........was I really going that fast officer??!!"
weetrav is offline   Reply With Quote
Old 6th April 2011, 09:05 PM   #11 (permalink)
Mook is Not posting from this account anymore
Use Mookistar if you need to contact me
+1
If your worried, buy a different car
Mook is offline   Reply With Quote
Old 6th April 2011, 09:07 PM   #12 (permalink)
When I saw the title I was like "oh no not another one" now search on google R35 engine blown, it links you to this one
Old 6th April 2011, 09:07 PM   #13 (permalink)
enshiu's Avatar
Originally Posted by Mook View Post
+1
you can blow up any car it's not a matter its just that tuning does not always succeed on standard pistons/transmission.
Old 6th April 2011, 09:13 PM   #14 (permalink)
TAZZMAXX is ...............
ADMIN
TAZZMAXX's Avatar
As my Dad used to say when I was a babbling teenager, "engage brain before opening mouth".
Translates nicely to this thread.
Old 6th April 2011, 09:19 PM   #15 (permalink)
What's with the defensiveness? The thread title is, deliberately, attention grabbing, the content is marked clearly as hypothetical. And, so what if a google search ends up here, if anyone read the thread they would see that it is an imagined situation.
This is a question a lot of owners, pondering tuning, would like answered.
And it's not about being "scared", it's about making an informed decision. What is wrong with that?
Chill out people!
Andybrew and bobel, thanks for your thoughts.
Old 6th April 2011, 09:22 PM   #16 (permalink)
Zed Ed's Avatar
Lighten up
The OP's question is fair
One thread, on top of all the other crap on the intaweb, will make no difference
Old 6th April 2011, 09:40 PM   #17 (permalink)
GTRSTAR's Avatar
This thread has a stupid title, however, it does carry a sincere concern that must be shared by people who tune their cars and want to know what happens if things go wrong.
The sticky about the engine change program is even more ridiculous if you ask me.
Old 6th April 2011, 09:41 PM   #18 (permalink)
The briefest of searches would have given all the answers the OP would have wanted.
The titles is deliberately misleading, if he wanted to ask a sensible question it would have been along the lines of "IF my engine/gearbox were to break when tuned..." etc.
The question has been asked and answered almost more than any other on here FFS...
Old 6th April 2011, 09:44 PM   #19 (permalink)
+1
Not often we see eye to eye, but in the interests of not unfairly damaging Nissan's reputation, would you change the title of this thread please?
Old 6th April 2011, 09:45 PM   #20 (permalink)
Steve is Mr GTR
GT-RDC Founder Member
Steve's Avatar
Cars owned: Nissan Skyline R33 GT-R "V"Spec
For once david - we agree !! I would go so fa as to say T*sser for posting such a thread, but then that's me speaking my mind !
Keep it on the Black Stuff
Steve + A-BEUT + A1 BEUT + Kermit
HARDCORE MEMBER
2008 Nissan GTR Black Edition (Racing "Fastest Colour" Red)
1997 Nisan Skyline R33 GTR V Spec (Midnight Purple, the only Colour for an R33 GTR)
1991 Honda NSX Type R (Vibrant Red)
2011 Porsche Cayman R (Peridot Green)
2108 VW Golf R (Saffron Gold)
2003 Mazda MX5 (Blue)
Steve is offline   Reply With Quote
