Replacing engine oil - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 13th April 2011, 01:12 AM   #1 (permalink)
enshiu's Avatar
Goodmorning gents,
What engine oil should I replace in my VR38DETT and how many litres?
Mobil1 - 0w40 (OEM)?
Willall 10w60?
R35 GTR Track Build - NAGTROC - The Nissan GT-R Owners Club
or any other recommendation?
My car is for track and road use.
Old 13th April 2011, 08:13 AM   #2 (permalink)
Arcam is still into Track Days
Arcam's Avatar
Cars owned: Many & Various
Originally Posted by enshiu View Post
Goodmorning gents,
Willall 10w60?
I use Motul 5w50 Sport, this is an ester based oil and I have no doubt that Opie Oils may chime in on this one. I use OEM during Winter time as I do not track my car then.
If you do not get your engine oil really hot and are prepared to change it frequently after track days then the OEM oil is OK, you have to remember how much oil dilution takes place when on track due to excess fuelling.
Arcam is offline   Reply With Quote
Old 13th April 2011, 08:23 AM   #3 (permalink)
enshiu's Avatar
I am changing each 5000km/3000 miles.
Will that be enough on OEM oil?
At what temprature is the engine on track days?
Mine goes around 100 C.
Old 13th April 2011, 08:30 AM   #4 (permalink)
Arcam's Avatar
You will be fine with OEM oil based on that change regime and oil temp, I used to get my old R35 into the 105 to 110 zone, I suspect my new 2011 model will run even hotter.
Old 13th April 2011, 08:43 AM   #5 (permalink)
enshiu's Avatar
I will change every 5000km/3000miles all the oils including diff and tm.
Old 13th April 2011, 08:53 AM   #6 (permalink)
enshiu's Avatar
I think I need a mishimoto thermostat as mine OEm does 90 to 95 C the whole day sometimes 100 C
Will this help? New GTR Mishimoto Racing Thermostat R35 09+ | eBay
Old 13th April 2011, 08:53 AM   #7 (permalink)
Arcam's Avatar
If you are tracking a lot then this would be good, I change my diff oils evey 2 track days regardless, the engine oil as well. If you are going to run the FFL4 then change it at the same time as it is so inexpensive, unless you are going to fit a transmission cooler.
Old 13th April 2011, 08:58 AM   #8 (permalink)
Arcam's Avatar
Mine ran up to 105c which I don't see as an issue with a fully sealed and pressurised system, 85 to 90 would be better and this stat my well help. On tuned builds it will help a bit more but you are also into getting an uprated radiator as well.
Old 13th April 2011, 09:20 AM   #9 (permalink)
enshiu's Avatar
I will buy a GTC tune at max 650 hp. I will receive a bridge this saturday so I can work on my car.
Old 13th April 2011, 09:28 AM   #10 (permalink)
Arcam's Avatar
Speaking personally, I would not like to see more then 600 carefully tuned HP with stock internals, I am sure plenty will disagree but with track use the loads on the bottom end are magnified considerable considering the duration of the power delivery etc.
Old 13th April 2011, 09:36 AM   #11 (permalink)
enshiu's Avatar
me2 but CPR did 700hp with only injectors,intake, and turbos and No engine upgrade?
source CPR - CARPLANET RACING.COM
COBB TUNING 'ACCESS-PORT' ECU Reflashing Controller (with CPR Custom Stage 6 Tune Flash Map installed)
CPR 700HP HYBRID TURBOCHARGERS
CPR HIGHFLOW RACING FUEL PUMPS
RC ENGINEERING UPRATED FUEL INJECTORS
FORGE MOTORSPORT ALLOY ACTUATORS (with CPR Specification Spring)
CPR TURBINE OUTLET ELBOW PIPES
CPR FRONT Y-PIPE DE-CAT
CPR 3.5" FULL RACE CAT-BACK TWIN EXHAUST SYSTEM
CPR INDUCTION KIT & LARGER AIR FLOW METER HOUSINGS
BEFORE & AFTER POWER RUNS
Which is more safe GTC 650R or this one?
Old 13th April 2011, 09:40 AM   #12 (permalink)
Arcam's Avatar
I could not really say as I have not run either, I really like the CPR exhaust system but they "detune" that kit so as not to break the con rods etc, which IMHO is a waste. I would first forge the bottom end and whilst out would go with the turbo and intake upgrade along with injectors and leave it at that for track use.
Old 13th April 2011, 09:56 AM   #13 (permalink)
enshiu's Avatar
Benji_linney_GTC provided me this package:
accessport (already have)
titan
y-pipe
downpipes (catted)
injectors
intake
circa 620hp
Old 13th April 2011, 11:31 AM   #14 (permalink)
enshiu's Avatar
Where Can I buy Consult III? (ebay?) I want reprogrammed LC2 but, COBB does not have TCM update for JC04FA.
Old 13th April 2011, 11:51 AM   #15 (permalink)
Jm-Imports is sitting on 1293 @ the hubs
GTR Register Trader
Jm-Imports's Avatar
pop over my shop sometime..
we use motul 15 50 300v as recommended by JUN
Jm-Imports is offline   Reply With Quote
Old 13th April 2011, 12:17 PM   #16 (permalink)
enshiu's Avatar
At any time during business hours?
I thought 15w50 is for motorcycles?
Old 13th April 2011, 02:08 PM   #17 (permalink)
GTR Register Trader
Jm-Imports's Avatar
yep any time except mondays mate..
you can get motul for car racing also
Old 14th April 2011, 08:39 AM   #18 (permalink)
enshiu's Avatar
Really far by car like 5 hours from Cardiff.
Old 14th April 2011, 08:52 AM   #19 (permalink)
GTR Register Trader
Jm-Imports's Avatar
i thought you were local lol
Old 14th April 2011, 09:16 AM   #20 (permalink)
enshiu's Avatar
lol unfortunately not,
When I am in the neighbourhood of Newcastle on Tyne I will visit your tuning shop.
